I HAVE TOYOTA RELAYS , THEY CAME OUT OF THE OLDER TOYOTA 22R P/U AND THE 22RE 4CYL . P/U . THEY WOULD BE THE SAME FOR THE 4RUNNER AND WILL WORK WITH THE 2 OR 4 WHEELDRIVES . THE TOYOTA PART NUMBERS ARE # 81980 - 16010 FLASHER , # 81980 - 22070 FLASHER , # 28300 - 16010 STARTER , # 90987 - 02002 RELAY , # 90987 - 02004 RELAY , # 90987 - 01003 RELAY , $10 EACH . SMOG PARTS FOR THE TOYOTA P/U OR 4RUNNER 22R AND 22RE .THE PORTED VACUUM PART NUMBERS ARE , # 084600 - 3220 , # 184600 - 0510 , # 89570 - 14060 , # 89570 - 20160 . $10 EACH . I HAVE EGR VACUUMS # 25870 - 65010 , and # 25690 - 35010 , $10 EACH . AND I HAVE 3 , 2 WIRE IDLE SOLENOIDS , 1 , 1 WIRE IDLE SOLENOID FOR THE CARBURETORS , $10 EACH . ALSO I HAVE A NICE USED SET OF STOCK SHACKELS WITH BOLTS AND NEW BUSHINGS THEY WOULD FIT 1979 - 1985 4X4 FRONT. $20 , 2 SHIFTERS FOR THE TOP SHIFT TRANSFER CASES FOR A TOYOTA 4X4 . $25 , A SHIFTER FOR THE 1986 TURBO R151F 5 SPEED TRANSMISSION $25 , AND I HAVE HEADER COVER FOR 20 R AND EARLY 22R $10 IF INTERESTED PLEASE CALL (559) 326-4720 PICK-UP IN FRESNO/CLOVIS CA. AREA .
