Roaring sound from Newly install Third Member
Started by Michael Wollinsky, July 02, 2011, 09:38:39 AM
Michael Wollinsky
 :help: someone tell me whats goin on its got a shake then it goes to a noise like the diff doesnt have any oil in it :shake_head:
Hand built and driving daily
jrock
Used or new/rebuilt third?
Sounds like a bearing is bad.
Wermz84
Shake??  is your drive line loose or out of balance?
I like to Drive!
Michael Wollinsky
It was used but it is fresh out of my buddies truck and the driveshaft has a couple of dings in it
jrock
Check your pinion flange for play. There should be none. Then spin the pinion flange without the drive shaft and tires. Check for grinding as you spin the flange.
Other than that, spin your tires individually and check that the main bearings are good.
Michael Wollinsky
I can't spin them individually I got a locker and ill check all the other stuff I took the driveshaft off its got dings and is bent thanks everyone for there input so far more comments are appreciated
Michael Wollinsky
Quote from: jrock on July 02, 2011, 07:18:43 PM
what kind of grinding? Sound or should I feel it
4RunnerChevy
Geez its a rear, take it out and examine it, it takes about an hour or less to remove.  Less than it takes to ask questions.
Goldrush
Quote from: 4runnerchevy on July 03, 2011, 02:38:12 PM
:thumbs: :yesnod: :clap:
Michael Wollinsky
Already done that no signs of wear or tear on ring and pinion the flange isn't loose either
4RunnerChevy
Quote from: ol blue on July 03, 2011, 12:45:53 PM
Ok, a dinged driveshaft is waiting for trouble.  Fix that.  You can put it on stands and diagnose.
Wermz84
I think that is a lot to do with it.
I like to Drive!
Michael Wollinsky
#12
Yea I'm just hoping it hasnt wore out the pinion bearings again the a pain
ZUK
Quote from: ol blue on July 03, 2011, 07:19:26 PM
If the pinion is still tight...and it didn't make this noise for the other guy then I would tend to think it's something else
driveshaft uj's not clocked correctly?
bad radials?
driveshaft out of balance?
pinion angle on rear pinion up too high or down too low?
           www.gearinstalls.com
2001 White Xtracab Taco 3.4L Auto TRD
88 Runner/V6/auto/31"/5.29gear
