Author Topic: need help with 4.88's  (Read 1166 times)
bluesboy707
  • Male Posts: 63
  • Member since Sep '10
« on: Jun 22, 2011, 08:34:27 PM »
what years yotas came with 4.88 gears. im going to the junkyard tomorrow.
Toyota aka jeep recovery tool :P
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
Re: need help with 4.88's
« Reply #1 on: Jun 22, 2011, 08:41:20 PM »
Check here
http://home.4x4wire.com/erik/diffs/
I know there is a special code and I think the pinion nut is white.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #2 on: Jun 22, 2011, 09:26:24 PM »
G144 on the door tab
v6 3rd gen runners
there 487's
get a supra lsd while your there and have a factory 488 lsd diff
I ve ran them there awesome for front or rear
bluesboy707 [OP]
  • Male Posts: 63
« Reply #3 on: Jun 28, 2011, 01:21:43 AM »
great advise guys thnx. i picked them up those 4.88s are awesome i can only imagine how the 5.29s are lol. i got the gears out of
2 different runners.  o, what are your guys thoughts on e-lockers vs air lockers? just lookin for some input, not sure witch way to go.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Jul 04, 2011, 07:38:25 PM »
I perfer ARB over the e-locker. I think they are stronger. But, I do not know if ARB make a locker that will work in the 4:88 Toyota diffs, the housings are built different then the standard V-6.I have heard that you can use the 4 cylinder ARB in the 4:88 housing but you have to use different bearings or some like that. Do not know how true it is because I have never seen one. Be easy on the factory 4:88 gears because there is no after market support as far as gears that I know of, so that leaves you with OEM from the dealer at about $1,000.00 for a ring and pinion set. That is the reason I never ran them and sold the two diffs I had, I break R&P's.
