Author Topic: carb issue or fuel line?  (Read 2629 times)
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« on: Jun 16, 2011, 05:58:10 PM »
I have a little issues with a 22r carbed 84 4-Runner, the po said it maybe the fuel line that connects to the fuel filter may have a crack in it, since he did not replace that one but the other one he did.
Anyhow the issue is that does not want to start without a cap full of gas into the carb, then it starts right up. Basically, its draining from that area or draining back somewhere. They said it should start with reguar day starts, well it was for a lil bit , but not anymore. I wonder what it could be.
The po also said the carb was rebuilt so maybe thats not the issue. or is it?
Thanks
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
Re: carb issue or fuel line?
« Reply #1 on: Jun 16, 2011, 10:28:11 PM »
sounds like the carb might have a problem witht he shut off needle not closeing off completely and it is causeing the fuel to flow backwards :twocents:
[img]http://bo
REG535 [OP]
  • Male Posts: 1,083
    • Buy me a cigar
« Reply #2 on: Jun 17, 2011, 01:25:52 PM »
Thanks for the reply.. I need to look at a carb diagram or a picture of where the shut off needle is ,, can you adjust them so it closes completey so fuel does not go backwards as you said?
1stgenboy
  • Turtle Points: -2
  • Member since Mar '05
« Reply #3 on: Jun 22, 2011, 09:35:44 PM »
First, check the sight glass and see if there is fuel in bowl when you are experiencing this problem.  If you don't then perhaps your bowl is going dry, but it would be likely do to a crack or some other catastrophic failure.  If you do then, with a flashlight and your choke wide open, look down the throat while opening the throttle quickly and see if you see a squirt.  If not, the accelerator pump circuit of your carb is bad.  If the vehicle has sat for a long time it could be that it is just clogged with varnish and it might clear up with an additive like techron or Seafoam.  Hope this was helpful.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #4 on: Jun 22, 2011, 11:24:17 PM »
Also check your fuel lines going right out of your tank. Those were completely rotted on my old truck so I lost gas everytime I parked till I finally figured out that's where it was leaking
REG535 [OP]
  • Male Posts: 1,083
    • Buy me a cigar
« Reply #5 on: Jun 23, 2011, 09:54:27 AM »
Thanks for the replies guys. Sometimes it starts fine other days it needs help. I looked at the fuel lines they seem new, I need to look inside the carb for that issue. I believe it has sat for a long time without being started or driven enough.
Also the fuel filter sits on the frame by the fuel tank, I thought the fuel filter was supposed to be bolted with a bracket inside the engine bay, maybe am wrong on a carbed 84'. I doubt that has anything to do with it. I am sure its carb related or the ciruct maybe as 1st gen said.
yotacrawler1
  • Turtle Points: 2
  • Male Posts: 259
  • Member since Sep '11
  • 1985, on wontons
« Reply #6 on: Mar 26, 2013, 02:08:57 PM »
posting in this thread instead of cloggin up otheres with a new one
My carb has exact same issue. it was running kind of poor. and wouldnt start without being primed. i took carb off and down to the 3 sections and cleaned bowl and everything out. bowl was real dirty.
Truck runs wayyy better now. but still wont start without a prime.
and Sight glass is Dry of fuel if it sits for me then about 15 mins. so would this be cracked fuel line issue??
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #7 on: Mar 26, 2013, 03:30:31 PM »
i had problems with my carbed 22r when my fuel filter was dirty.... I replaced it every month or so... no big deal though, it was like $5
yotacrawler1
  • Turtle Points: 2
  • Male Posts: 259
  • 1985, on wontons
« Reply #8 on: Mar 26, 2013, 03:32:25 PM »
oh thanks i shoudl've added that. filter is new and clean tank is clean. and fuel pump holds pressure good.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #9 on: Mar 26, 2013, 03:33:14 PM »
Sounds like a leaking fuel line to me. Just crawl around and look for a leak.
dt
  • Turtle Points: -107
  • Member since Oct '07
« Reply #10 on: Mar 27, 2013, 08:26:05 PM »
I say accelerator pump also,pull air cleaner,look down primary ,while you or someone else punches it ,watch for gas stream or not
yotacrawler1
  • Turtle Points: 2
  • Male Posts: 259
  • 1985, on wontons
« Reply #11 on: Mar 29, 2013, 08:43:52 PM »
the accelorator pump works when carb has fuel in it. problem is the carb drains the bowl  if it sits.
yotacrawler1
  • Turtle Points: 2
  • Male Posts: 259
  • 1985, on wontons
« Reply #12 on: Mar 31, 2013, 08:42:23 PM »
Soo...... ripped all vaccum lines out and bought 5 feet from napa, Started from scratch. replaced fuel lines. Did the like mechanicle accelorator pump. and the auxillury one with the 1 vaccum line coming off.. both were bad. idk what fixed truck. or if all of it did. but she purrs like a kitten now and starts up first crank  :) :) :) thank you guys
89MiniTruck
  • Turtle Points: -2
  • Male Posts: 15
  • Member since Sep '04
« Reply #13 on: May 06, 2013, 06:05:46 PM »
 :clap: Glad to hear it.
Toyotahilux80
  • Male Posts: 103
  • Member since Apr '12
  • If it ain't broke fix it till it is!!!
« Reply #14 on: May 08, 2013, 05:19:22 PM »
Dont think it's a fuel line leak, had dam near the same prob and it was my mixture control cylanoid, good  luck with the fix :thumbs:
IF IT AIN'T BROKE FIX IT TILL IT IS!
Last post Nov 09, 2020, 05:17:18 AM
by Lewis Hein
Last post Mar 20, 2009, 12:34:36 PM
by 83MT
Last post Sep 29, 2010, 01:33:49 AM
by emsvitil
Last post Mar 06, 2011, 11:37:29 PM
by GreenYoterKrawler
Last post May 23, 2011, 04:50:51 PM
by Slolyfe
