Author Topic: SM420 into mini truck?  (Read 1776 times)
rEdnECkwHeE1eR
  • Turtle Points: -68
  • Male Posts: 1,430
  • Member since Jun '02
  • Still tipin'
« on: Oct 10, 2002, 02:34:44 AM »
I think some where, might have been on here, I herd some one makes an adapter to bolt a 22 series moter to an SM420 who makes this? then you could use like 4.10 axle gears because of the way low 1st (7.05:1) and then the 4th gear would be like an overdrive but the first gear/4.10=28:1 combo would still be lower then a stock toy 5spd(3.93)and 5.29s=20.8:1which doesnt seem like a huge dif but it is once you add tcaces in
2.38x4.7x7.05x4.10=323.3:1
2.38x4.7x3.93x5.29=232.6:1
its like 100:1 lower! but I guess this would be trail only rigs:dunno:since the 420 has slow shifting.
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
Liquor up front
Poker in the rear
Paul_Elbisser
  • Turtle Points: 43
  • Male Posts: 329
  • Member since Aug '02
  • Supra Powered
    • KraZyfly
Re: SM420 into mini truck?
« Reply #1 on: Oct 10, 2002, 05:00:01 AM »
http://www.ottindustries.com/toyota_22r_22re_sm_kit.html
This may make the frount driveshaft to short for much lift. And the Marlin Toybox adapter is cheeper, and one piece. I wouldn't do it unless it was a trail rig, and had dual cases. But the SM465 trans are cheep.
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #2 on: Oct 11, 2002, 05:00:22 AM »
single case will work, I run a 420 with a single case :)
The tcase shifts fine, no worse than the toy one - in fact it feels MUCH tighter..
Brandon Miller
RCRC, Sacramento, CA
Last post Mar 29, 2007, 06:26:49 AM
by MiniSimp
Last post Nov 15, 2011, 06:56:02 AM
by LCOwner
Last post Feb 18, 2013, 06:19:42 PM
by locked 4x4
Last post Jan 23, 2016, 05:28:08 PM
by vikingsven
Last post Mar 14, 2017, 07:17:29 AM
by GuyonaBuffalo!
