98 4runner SAS questions and help
Started by slim202020, June 08, 2011, 03:47:54 AM
slim202020
So I think I got my trailer sold today so I can buy the runner back from the insurance company. I need some help on what axles to put under it and I'm kinda on a tight budget . I also had the thought cross my mind of putting Chevy axles under it. Need some input. Do they make fender flares for a 98 runner?
Toymin8r
You either need to find an early 80's Jeep Wagoneer Dana 44 or have a custom housing made with a left side drop and use factory Toyota parts to fill it.  The custom housing route will be the most expensive but probably easier to get the parts than finding a Wagoneer front axle.   Also, the I believe the Wagoneer axle will be the same width as your 4Runner's rear axle.  If you have the Toyota axle made to stock width you will need 3" wheel spacers to match the rear.  If you have the custom Toyota housing made to match the rears width you will have to have custom axle shafts made too.
bigarms23
get a ford or jeep dana axle with a driverside pumpkin and bush wacker probably have the flares of find a set that came on the 98 4runner in the first place. but usually you can find a d44 from a grand wagoneer for 100bucks
