you said ur t-case that is connected to the g52 is forward shift. so in order to do a dual tranfercase setup and keep it forward shift, your rear t-case is going to be top shift, while ur crawl box (which is between the t-case and tranny) will be forward shift.
when you say tripple stick, are u talking about doing two crawl boxs and a t-case? or dual cases with twin sticks? Dual cases with triple stick (see the write up on pirates board). Moves up the (dual shifter for the rear case) up next to front shifter (on either side).
Yes that is the set up
so dual case is the set up? or tripple cases?
hmm wow. sorry, ive never heard of a dual case with tripple stick, like that picture.
Started by pitter New Announcements and Info
Started by pitter General 4WD Discussion
Started by dirtgreg General 4WD Discussion
Started by trdvet Engine
Started by AtTiLiA « 1 2 » Jeep Tech
