Author Topic: (helpppp)is it bad to take head bolts out after u torque a new head gaskit down  (Read 4337 times)
jakesny530
  • Member since May '11
I put a new head on and head gaskit and did the torque it said and I need to.double.check torque on cam so is it bad to.take the head bolts out and the rocker arms...?buy new gaskit or am.I.good sence I didn't pull the head actually off
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
well it's never good to do it. if you have not put water in yet you might get away with it butt short answer is
better to but a new one and be sure.
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
X2
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Head gasket, is a one time thing !
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
X2 If you loosen the head bolts after you tightened them, replace the head gasket so you won't have do it all over again later.
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
crawlnbeaver
  • Male Posts: 19
  • Member since Aug '09
cheep insurance! replace the head gasket...
jakesny530 [OP]
I havnt started. put oil.or water in yet and don't have that much money so I'm.just gona cross my fingers and pray wen I slap.it back.together she'll run :) and thanks for the advice hope.I.don't have to.do.it all again and feel like a dumba$$ for not listen
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
Its cheaper to do it now than  to have to replace the gasket + oil and filter. just replace the gasket.
Do you need a Hammer?
zippo
  • Turtle Points: 569
  • Male Posts: 1,554
  • Member since Nov '08
    • oppiz.net
Fel-pro head gasket is like 28 bucks a factory one if in the 30's
If you see it, its for sale.
yota13
  • Turtle Points: -1
  • Male Posts: 26
  • Member since Sep '11
pull the spark plugs then the head bolts you will be fine
Toyota a reliable friend that never let's you down and loves to keep on truckin
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
I'll never use a fel-pro head gasket again, NEVER!
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
I have never had to go back to check my cam journal bolts but, ONCE, I changed out a cam without replacing the HG. Drain the coolant, pull the spark plugs, and cross your fingers.
You have the timing cover bolt, the weight of everything attached to the head, and the gasket "stick" hopefully holding it on till you get the cam in. I also stuck some bolts back in with spacers to hold things in place so I didn't knock it loose.
I only did it because I was in a bind. If I had heard or saw that the head broke loose, I wouldn't have continued.
jakesny530 [OP]
Well it worked I took.the bolts off and tightin my cam bolts thank god to.they were off a little in torque and my head gasket is.still holding now time to fix that clackk and whinning bearing and the runner will be a beast
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
you just replaced the head gasket and have a clack? that isn't good
Last post Jan 14, 2004, 06:20:05 AM
by Toyoballs
Last post Jun 08, 2007, 07:27:23 PM
by RynothealbinO
Last post May 03, 2009, 05:16:40 PM
by GJToyotabug
Last post Nov 26, 2009, 02:02:10 AM
by Snowtoy
Last post Feb 01, 2013, 08:53:32 PM
by Cheesemaker
