coyote, did you mess with the idle jets at all?
I pulled all the jets on the carb that came with the engine and here is what I got:primary/secondaryAir jets - 165/160Main fuel - 130/140Primary idle - 50Secondary idle - 50double pump jet at top (don't know what it is called) - 50I will compare this to what I have in my 32/36 in my truck tomorrow.
~2300 ft. Doesn't it appear that the plugs show signs of running lean? The whitish color on the probe and the extremely white part (not sure on the names). I would think larger air jets would allow for a leaner environment.I sucked up and got the pro torque cam from LC with a 13 degree overlap, 102 intake centerline and a 118 exhaust centerline. This should allow me to fill the cylinder much better than my current cam. The pro torque cam has a lift of .455 and will work with stock valve train and with the stock 20r/22r setup. I will also be able to degree the cam 100% correct and adjust from there if I need to move the power band. I figured that since I have some smaller jets with my old carb then I wouldn't need the economy jet set from lc, so I went with the performance jet kit. That should allow me a great combination of jets between the kit and the two carbs I have now.This should allow me to get this thing running pretty dang well for what it is and I can hopefully finally put it all to rest once tuned.So, what kind of issues could the slight piston slap (mentioned on the first post) cause and should it be attended to or just leave it. I really only want this engine in the truck for maybe 5yrs and probably won't see a ton of miles. I was reading around and it seems to address the piston slap it requires a rebuild. Is this true?
Something it has done since putting it in the truck is when you first start it up it sounds like there is a rattle for about 1 second (definitely coming from the engine side of things). Could this be a valve? Only does it on start and I believe a cold start only. It goes away and is never to be heard again. Now when driving under load at higher rpms there is a ping, I figure it was due to the timing. I timed it again and it still didn't go away. This led me to get the adjustable cam in order to get the timing on everything as good as possible.
Started by Asher General 4WD Discussion
Started by ctToyBoy General 4WD Discussion
Started by Runninthetrails General 4WD Discussion
Started by mikerob General 4WD Discussion
Started by solidaxle16 Toyota Pickup/4Runner Tech 1979-95
