Author Topic: shackle/pinion angle?  (Read 3428 times)
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
« on: May 24, 2011, 04:36:21 PM »
i heard somewhere that for every extra inch of shackle your pinion will change 1 degree.  for example a 4 inch longer than stock shackle will change your pinion angle 4 degrees.  can anyone tell me if this is true?
raidernation
  • Member since Jun '11
Re: shackle/pinion angle?
« Reply #1 on: Jun 09, 2011, 03:35:32 PM »
I dont know about that formula but you don't to put too much angle on your pinion (you'll starve it of oil) so try to keep it reasonable.
crazy white boy
  • Turtle Points: 3
  • Male Posts: 77
  • Member since Jul '09
« Reply #2 on: Jun 25, 2011, 10:20:54 PM »
i have never heard that. i put mine about 2 degrees down and it works just fine
Joshua 1:9
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Member since Mar '10
  • Honey Badger
« Reply #3 on: Jun 25, 2011, 10:39:33 PM »
So your pinion points to the ground ???
To the original poster, I do believe your pinion angle changes with longer shackles. But I don't think it is enough to cause problems.
crazy white boy
  • Turtle Points: 3
  • Male Posts: 77
« Reply #4 on: Jun 25, 2011, 10:45:59 PM »
i meant 2 degrees down from straight in line with the driveshaft
Joshua 1:9
91 ex-cab
  • Male Posts: 1,660
  • Honey Badger
« Reply #5 on: Jun 25, 2011, 11:10:20 PM »
Ah, that makes more sense. I've never really heard of people having problems starving the pinion of oil.
4RunnerChevy
  • Male Posts: 1,426
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #6 on: Jun 26, 2011, 06:45:59 AM »
You can over fill it, if your worried.
marktrd4x4
  • Member since Apr '10
« Reply #7 on: Jun 26, 2011, 02:46:18 PM »
The greater the pinion angle the greater strain on the joint and pinion bearings. The only formula to use would be to measure @ the pinion u joint and at the transfer u joint. Using an angle gauge and the difference between the 2 angles should not be greater than 4 degrees. Generally speaking most rigs I've seen don't shim up the pinion angle they just get a modified length drive shaft. If you shim the pinion angle the using the leaf springs the center pins are more likely to shear off. But if your more like to be on the highway than on the rocks then shim to your hearts content.
Last post Jan 17, 2005, 08:58:00 AM
by don25
Last post Jan 22, 2007, 07:00:08 PM
by yotaboy79
Last post Apr 11, 2007, 12:09:19 PM
by havik
Last post May 26, 2007, 02:09:06 PM
by Petzl21
Last post Apr 22, 2008, 07:07:30 AM
by SLIVER
