Yeah, sure ! Your having too much fun in you new rig. Good luck on your neeew venture !
yeah thanks. my luck will be that I get it running and after about 30 min of running I sling 3 rods and crack the block
They did but my motor sat too high and I didnt want to do a body lift or modify my hood. The way its sitting now is pretty good. I kept the brackets for it and the compressor along with the belt incase later on I wanted to go to it but I have my little compressor that does just fine for now. My next project is turning my smitty bumper into a storage tank with fittings on the end caps.
The harrison AC compressor will burn up in minutes if you use it for OBA, even if you have a pre-oiler
my friend had one on his truck and he said the same thing. Worked like a champ. Wasnt the same one off a 4.3 but still worked just fine so i would assume the one off the 4.3 would hold up since its beefier than the one he used
Started by 93Jspec New Member Check-In!
Started by BLACKDOG Project Research and Build-Ups
Started by ErikB General 4WD Discussion
Started by davidr34 Toyota Pickup/4Runner Tech 1979-95
Started by harley1615 Engine
