4Runner tire carrier(Done)
Started by LD, April 27, 2011, 09:23:42 AM
LD
I finished up my rear bumper last week so decided to start my tire carrier yesterday. Im almost done
I turned down a piece of 1-3/4 barstock for a hinge and used some old 3/4 heims.
I need to add some gussets and mounts for my hi lift
The best place to find a helping hand is at the end of your arm.
86moneypit
86 Runner 529s locked duals 37s
96 Runner 5sp. 3.4 32s DD
04.5 Dodge 2500 CTD With Go Fast Stuff On It
Drive it like you stole it
blackdiamond
I like it.  How about a close up of the finished pivot point.  What keeps the heims from dropping when the other end isn't supported?
LD
I will take some tonight. There's nothing that keeps it from dropping having the two heims bolted to the same plate keeps them from dropping. If it was just one heim icheapld pivot in all directions but 2 will only allow it to pivot side to side not up and down. Its hard to explain but it works great. I have used that design on several carriers and it is very strong and cheap.
blackdiamond
A picture would be great for documentation, but I think I understand it now.
LD
I like this setup because i can adjust the height of the carrier. With weight on it and it sags on the one side i can raise or lower it
LD
Spent a few hours finishing my carrier. Got it primed.
Made some knobs on my lathe for holding down my hilift.
Blued the knobs
874runnertoys
LD
Finished it up yesterday. I like how it turned out
junya92toy
Quote from: LD on April 27, 2011, 04:30:54 PM
The arm lengths would need to change for it to drop.
GAP3RKi113R
Eat Sleep TOYOTA
LD
Made some corner supports for my bumper
jeffs84runner
How is it down the highway?  I had one on my 84 and when I'd start hitting the tiny whoop de doos in the highway mine used to shake back and forth like a mutha, enough to shake the truck.  I used a nerf football between rack and tailgate, helped kinda.
1984 4runner sold :-(
1997 FZJ80 sold :-(
1995 SAS'd 4runner sold :-(
Current Whip 1996 LX450
Rubicon Tested, Mother Approved...
Buy Marlin!
LD
Mine hardly moves. The corner supports really helped now no movement
migrig854runner
defrag4
impressive, whats did you use for the actualy swing portion?
brockbuilt85
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
junya92toy
Quote from: defrag4 on August 23, 2011, 10:21:00 AM
the hinge?
LD
Yota87Truck
I like the use of the heims.  I have always worried about making one and the carrier starting to sag and not re aline to latch closed... This method is adjustable!
steamer88
Yes, very well built! Nice and clean, looks like that's how you do things. Do you have any close ups of the latch? And did you do any thing to keep the assembly from rocking front to back?
smart quote here...
craigbalex
Nice job looks like u do great work
Doable
i know this is an old post but how has the  tire carrier held up over time ? Anything you would change to make it better or more durable ? Thanks
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
Artie
Yes! What he said. I'd like to know how this is holding up.
RockaRunner
Came out great! I have one also but hate how much rear view vision it takes away when driving it.
