Broken peddle?
Started by Paul_Elbisser, November 03, 2002, 06:28:59 AM
Paul_Elbisser
I never seen this before. And on a street truck driven by a girl.
 The bracket that the clutch pedle hooks to is broken at the bend between the clutch switch, and the return Spring. I am going to atemp to get the mig welder in and patch it back together. I just thought I would give some people a heads up, and ask if anyone has seen this before.
 It's an early 90 3.0 V6 extra cab 4x4. I am going to look at mine when I get a chance to see if it is showing a crack.
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
hawaii500_1999
#1
i had it happen to my 1980 two wheel drive.
i drilled and taped a block that fit between the bracket and bolted across then came up from underneath with a 1/4-20 bolt.  it was a pain getting in there with a drill but it fixed it.
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
yoda
#2
the clutch pedal is a common problem. Friend had his break on 91 v6 xcab
cruzila
#3
I had the big clutch/brake bracket crack on my T100 :reg:
85yodaman
#4
Seen two of them, 1993 and 1994.
Easy fix If you like to weld in a tight spot
The only difference between  Ford, Chevy and  Dodge is FIFTY FEET in a WRECKING YARD!
Paul_Elbisser
#5
Yep I welded it in place. Put some wet rags down to cover the carpet, but not enough. Oh well, beats paying someone to fix it.
Paul Elbisser
One of Those Guys
mr4x42u
#6
smell that?smells like a fire?Get the  :beer:to douse the flames.... :smack: :smack:well it did not burn to the ground! :up: :up:or did it? :dunno:
Paul_Elbisser
#7
No just a few spots. Almost like a cigerette fell on the floor. Mat will cover it!
Paul Elbisser
One of Those Guys
Brandon
#8
yea, those things suck - I can tell my welded gusseted one is about to break AGAIN.. I need to do something different..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
