Author Topic: 22r wont idle or run well  (Read 4045 times)
fatkidskickrocks4x4
  • Turtle Points: -2
  • Male Posts: 216
  • Member since Apr '08
« on: Mar 29, 2011, 02:46:57 PM »
Took the carb apart soaked it in cleaner rebuilt it set float to specs idle cut solenoid is working and I'm getting way too much fuel, fuel pump is new I'm stuck at a gas station now tryin to figure it out
If you have to go "balls deep" you aren't doing it righ
fatkidskickrocks4x4 [OP]
  • Turtle Points: -2
  • Male Posts: 216
Re: 22r wont idle or run well
« Reply #1 on: May 03, 2011, 01:50:13 PM »
Ok, so I've got too much vacuum?
Zukied
  • Member since Feb '10
« Reply #2 on: May 04, 2011, 11:21:40 AM »
never heard of to much vacuum , howd it run after the rebuild before the way to the station
  • Turtle Points: -2
  • Male Posts: 216
« Reply #3 on: May 08, 2011, 09:59:33 PM »
I think I got it. It was a vacuum leak on the intake manifold. But now it idles at 2000 rpm. Do you know how to adjust it? And it runs good for 10-15 miles everytime I take it apart then sputters and dies. I installed a 2nd fuel pump and its doing better. Also, where the throttle cable hooks up to the carb the nut was loose so I tightened it and now the throttle doesn't want to close?
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« Reply #4 on: May 08, 2011, 10:13:59 PM »
should be a philps screw on the passenger side to adjust the idle if its too high, if its not that you've probably got a vaccum problem
  • Turtle Points: -2
  • Male Posts: 216
« Reply #5 on: May 08, 2011, 10:17:01 PM »
It won't idle unless its all the way in and the rpms won't go below 1800 now... any ideas on where to look for the leak?
  • Turtle Points: -2
  • Male Posts: 216
« Reply #6 on: May 11, 2011, 01:30:39 PM »
The float isn't flooding but its pushing too much fuel into the motor
whatsayota?
  • Male Posts: 137
  • Member since Nov '09
« Reply #7 on: May 13, 2011, 09:20:17 PM »
u figure this out please post what ur fix was because im having very similar issues and am totally lost on what to do
84 xtra cab, dauls W/4.7, 5.29s, detroit rear/arb front, caged, longs, recentered H1s and 37s, my DD
  • Turtle Points: -2
  • Male Posts: 216
« Reply #8 on: May 14, 2011, 04:12:51 AM »
Still haven't got it... trick little bugger! I'm gonna check the head and intake manifold to see if it is warped. Sometimes it gets waay too much fuel and others the float bowl is dry... it'll run fine then start to buck and want to die
whatsayota?
  • Male Posts: 137
« Reply #9 on: May 14, 2011, 08:06:20 PM »
mine simply refuses to run correctly on a stock carb but runs like a dream on my 32/36 weber. stock carb it misses and u can see a shake to the motor and if i try to drive it it bogs and dies
  • Turtle Points: -2
  • Male Posts: 216
« Reply #10 on: May 15, 2011, 12:54:57 PM »
I only have a stock carb lol it will run fine for 6 or 7 miles then die then I let it sit for 10 min and it'll run again. If I open the throttle and blow down the carb and clear gas out it will run fine for the same but its less of a wait :turtle:
  • Turtle Points: -2
  • Male Posts: 216
« Reply #11 on: May 15, 2011, 01:24:07 PM »
Also the fuel pump keeps losing prime
  • Turtle Points: -2
  • Male Posts: 216
« Reply #12 on: May 15, 2011, 02:40:08 PM »
And its worse during low pressure systems (weather)
  • Turtle Points: -2
  • Male Posts: 216
« Reply #13 on: May 26, 2011, 10:53:51 PM »
Haha well, I found a hole in the pickup line
prawl44
  • Male Posts: 63
  • Member since Apr '11
« Reply #14 on: May 30, 2011, 05:16:11 PM »
a other way is what i did was took brake clean an sprayed around the lines a found my leak try that but thats good you found out the problem
  • Turtle Points: -2
  • Male Posts: 216
« Reply #15 on: Jun 01, 2011, 11:53:55 PM »
Yea , I sprayed around the carb and found that my throttle screw deal was leaking too
prawl44
  • Male Posts: 63
« Reply #16 on: Jun 03, 2011, 06:44:17 PM »
man thinking mine is doing the same but it smells real rich
  • Turtle Points: -2
  • Male Posts: 216
« Reply #17 on: Jun 04, 2011, 03:23:22 AM »
Mine ran rich but then it'd suck air and run like  :reg:
prawl44
  • Male Posts: 63
« Reply #18 on: Jun 05, 2011, 03:21:48 PM »
hmmm wonder if my carb is leaking somewhere els too
Last post Nov 14, 2003, 10:51:00 AM
by 95TacoTruck
Last post Mar 09, 2008, 03:27:01 PM
by toby
Last post Nov 13, 2008, 06:11:06 PM
by pumkin toy
Last post May 25, 2013, 09:12:07 PM
by phetty
Last post Feb 09, 2021, 09:36:19 AM
by Colston
