front lift springs on rear
Started by 19801981, January 19, 2005, 07:49:29 AM
19801981
 :confused:  some one said i could run front lift on rear is true and if so how would i make it plus u know that the fr. one side is little bigger well some tell me how to get more lift in the rear im wanting 8 to ten inches. :_order:  :hammerhead:  :nope:
Salvo
why would you want to go so high ??? springs are a diffrent length and center pin iis in diffrent location. But i suppose if you really want to you could do it... Also front springs are a stifer spring rate than rears
dirtyskivies
front springs would suck on the rear. not only is the spring rate somewhat higher. the rear frame rails are substantially wider hampering flex/function even further...
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
19801981
ok bad idea just trying to get around having to spend so much
donkeykong
Maybe they told you rears up front.  I have heard of several guys doing that, maybe you just got it mixed up
19801981
prob but i aint ill just settle for sky jacker 7in syst.
