1983 SR5 in dash gauges
Started by Brandon, June 22, 2002, 09:43:06 AM
Brandon
Great upgrade for someone without the tach etc..
$20
edit: Brandon I moved it here cuz of the good info. Maybe you will sell it :circle: Or delete the sell references and leave the tech :up:  Scott
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Brandon
#1
I know it works cause I ran it, what was wrong with the one you got? You know you gotta switch the pins around right?
Brandon Miller
95TacoTruck
#2
Please Elaborate on switching the pins I just plugged in the plugs and hooked up the speedometer and tried it and it didn't go.
95 Tacoma Extra cab, many mods to come........
Brandon
#3
he he, no it won't ;)
The stock and SR5 gauges have the pins in different locations so you need to get some needle nose or a pen or something and "pop out" the pins from the plastic connectors and re-order them. I'll see if I can find the diagram I used for ya. Now look I am saving you money ;)
What I am looking for is from "barney's orc archives"
Brandon Miller
Brandon
#4
For the record, here are the pinout of SR5 vs non-SR5 gauge for 83:
SR5     non-SR5     wire color       function
 1        1            GY           Right turn signal indicator
 2
 3        3            BR (B BR)    Speed sensor (-) ground
 4        6            GL           Speed sensor (+)
 5
 6
 7        23           YG           Water temp gauge
 8        9            RW           Panel lights (+)
 9        15           YR           Fuel Gauge
10        12           Y            Ignition switched power
11        21           YB           Oil Pressure switch (idiot light)
12        22           YW           Charge (idiot light)
13        14           WB           Ground
14                                  Tach input - must be wired to igniter
                                                 yellow
15        17           GB           Left turn signal indicator
16        16           RB           Panel lights (-)
17
18
19        11           G            4WD
20
21        19           BY           Seat belt
22
23        13           RG           High Beam
24        20           GW           Brake
for more info look here:
http://www.barneymc.com/toy_root/techtalk/accessor/sr5_gage.htm
Brandon Miller
Brandon
#5
yea I still got it...
Send me your addy and I'll figure shipping unless you can come to sac n get it.
Can't beat $20 ;)
Brandon Miller
95TacoTruck
#6
Hey Brandon, sorry man I no longer need the guages I snagged an 85 dirt cheap so I am selling the 83.  Thanx anyway though
