Author Topic: Broken pistons  (Read 4979 times)
65714runner
  • Turtle Points: 35
  • Member since Dec '09
Broken pistons
« on: Mar 23, 2011, 09:32:26 PM »
I recently bought another 4runner for parts.  I pulled the motor to put in my 85 runner but wanted to go through it first.  The runner ran fine.  I started into the motor and knew it had been into in about 10 min.  Got it all apart and it has already been bored .75mm over and still has hone marks from the rebuild.  My problem is all 4 pistons are cracked on the intake side of the motor and not sure what would cause this.
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Broken pistons
« Reply #1 on: Mar 24, 2011, 03:01:58 AM »
Thats crazy! Could it be just cheap pistons? What king of wall clearance do you have? Crazy timing/detention issue?
If you see it, its for sale.
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #2 on: Mar 24, 2011, 06:41:07 AM »
It was a little lean on the intake side.  The walls are still ok.  Cheap pistons was my first thought.
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
Re: Broken pistons
« Reply #3 on: Mar 24, 2011, 09:01:49 AM »
post up some pics if you can.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Rocksnail
  • Turtle Points: 3
  • Male Posts: 595
Re: Broken pistons
« Reply #4 on: Mar 24, 2011, 11:51:29 AM »
Are any of the valves messed up? kinda sounds like your Intake valves kissed the piston
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
Re: Broken pistons
« Reply #5 on: Mar 24, 2011, 11:53:58 AM »
that is a lot of overbore! but  iwould think cheap pistons or really bad tuning..... the pistons are aluminum, so its possible they got too hot and cracked
He did say .75mm
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #6 on: Mar 24, 2011, 03:01:03 PM »
Yes valves are good.  They all cracked on the skirt.  I will try to get pics later.
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
Re: Broken pistons
« Reply #7 on: Mar 24, 2011, 03:10:42 PM »
if they cracked on the skirt, its probably from piston slap.  your pistons are probably to small for the bore.
ABD Motorsports
#4475
KK6QDW
Re: Broken pistons
« Reply #8 on: Mar 24, 2011, 04:52:45 PM »
regardless you need new pistons. do the cracked ones fit tight in the cylinders??
zippo
  • Male Posts: 1,556
    • oppiz.net
Re: Broken pistons
« Reply #9 on: Mar 24, 2011, 06:33:02 PM »
So you are looking at .030" over.
Take it to a machine shop and get some LC Big Bore pistons. .080" over.
http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=63847A79-E8FD-4BD1-92D3-71FD1778805C
Re: Broken pistons
« Reply #10 on: Mar 24, 2011, 07:36:56 PM »
yea for $599 :ack:
unless youve got money to throw away just get some good quality pistons and dont bore over .040 inch
Re: Broken pistons
« Reply #11 on: Mar 24, 2011, 07:38:06 PM »
fwiw i have .060 inch over size pistons (1.5mm) and finding a replacement SUCKS
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #12 on: Mar 24, 2011, 10:02:50 PM »
Here is a pic.  All four are cracked in the same place.
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #13 on: Mar 24, 2011, 10:07:35 PM »
I need to check the piston to wall clearance, but i thought they were a little bit loose.  I am hoping that .040 over will work hate to do .060 hard to find pistons and seems to want to over heat easier on the trail.
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
    • Right Now Racing and Fabrication
Re: Broken pistons
« Reply #14 on: Mar 24, 2011, 10:11:24 PM »
the motor was def boared more than the piston size had the samething happen to a buddy
RNR FABRICATION ON THE EAST COAST!!! rightnowracingfabrication@gmail.com (814)-516-5176 like us on facebook www.facebook.com/rnrfab
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
Re: Broken pistons
« Reply #15 on: Mar 25, 2011, 08:05:50 AM »
He did say .75mm
thats what i thought.
ABD Motorsports
#4475
KK6QDW
zippo
  • Male Posts: 1,556
    • oppiz.net
Re: Broken pistons
« Reply #16 on: Mar 25, 2011, 07:54:42 PM »
There is alot of scuffing on the skirt of the piston. How do the bores look?
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #17 on: Mar 25, 2011, 09:39:43 PM »
Bores are ok I am still taking everything to the machine shop to see what I need to do.  Who ever build the motor after the last rebuild put is together dirty.  The main and rod bearing had little scuffing on them but crank and rods are ok.
Re: Broken pistons
« Reply #18 on: Mar 27, 2011, 03:07:53 PM »
:thumbs:
Jagdverband44
  • Turtle Points: -1
  • Male Posts: 155
  • Member since Mar '07
Re: Broken pistons
« Reply #19 on: Mar 28, 2011, 11:21:01 AM »
What a crappy engine job. So many a 22r ruined by hack rebuilders. That skirt wear was caused by piston slap which eventually cracked the pistons. Some foo used the old pistons and stuck some new rings on em'.   :thumbs:
I've got the most liftedest truck in town, that little jap truck done stand no chance gainst my Chevy. My Chevy gots a V8 more lift an bigger tires,and an exhaust system, whats yer tuna can got, a V4, and them tires look like they is offa Saturn Corulla. The dealer instulled my lift, so ya no its done right, you just try to foller me throo them rocks an see what a reel truck can do.
Redbeard1
  • Turtle Points: 54
  • Male Posts: 414
    • Project Pete
Re: Broken pistons
« Reply #20 on: Mar 28, 2011, 12:43:25 PM »
x2 Mine do great just make sure you get the pistons knotched for LC's largest cam just incase you ever decide to up grade.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
 __________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #21 on: Mar 28, 2011, 08:43:27 PM »
Droped it off at machine shop today the guy put .030 over pistons in a .040 over bore :mad:.
zippo
  • Male Posts: 1,556
    • oppiz.net
Re: Broken pistons
« Reply #22 on: Mar 29, 2011, 01:24:59 PM »
That is the problem with unknown engine rebuilders! There are so many easy ways/tricks that get a engine running good for about 10k miles "Rering" then it dies. Good catch!
Glade it didn't destroy your block! If you were local to me i'de say bring her over and i'de help ya slam her back together. I enjoy building Engines.
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
Re: Broken pistons
« Reply #23 on: Mar 29, 2011, 01:51:49 PM »
:headshake: thats exactly why you need to measure the bore and do a piston ring end gap when building.... flippin stupid people..... at least they didnt come apart on you!
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #24 on: Mar 29, 2011, 03:40:55 PM »
Well I hope that the bore will clean up where its at if not the next step is sixty over and i really hate to go that big.  I may try to find another block if that's the case.  There are some that can build engines and some that can not.  I thought this would just be an easy freshen up, looks like it wont be.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: Broken pistons
« Reply #25 on: Mar 29, 2011, 04:30:01 PM »
Sorry to hear that.    :headshake:
I like to Drive!
Re: Broken pistons
« Reply #26 on: Mar 29, 2011, 04:48:55 PM »
:therethere:  have him try some .040 over pistons hopefully they wont be too far out that you can do a good hone on the cylinders and run the .040 overs.
where are you ??  Mississippi??  Alabama??
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #27 on: Mar 29, 2011, 06:01:14 PM »
That's what we are going for.  Since it still has hone marks might be ok as long as bore was good to start with.  I'm in Missouri.
65714runner [OP]
  • Turtle Points: 35
Re: Broken pistons
« Reply #28 on: Apr 12, 2011, 03:40:11 PM »
Well I got my parts in.  What i did not know was that toyota changed blocks from 84 to 85 :hammerhead:  So I am looking for an 85 or newer block that way I can put my efi head on it.  I was told that there is a chance that I could put my fuel injection on the 84 head but I will still have to send everyting back and get parts for the 84.  For now I will just try to find a different block.  This is the reason you should research first.
Re: Broken pistons
« Reply #29 on: Apr 12, 2011, 09:37:04 PM »
yes they changed in 8/1984
newer pistons had a flat top and the block was shorter. 11.080 inches where the older one s were 11.280 inches
Last post Sep 20, 2006, 08:28:45 AM
by dune_it86
Last post Jan 10, 2007, 02:33:50 PM
by notajeep
Last post Oct 04, 2007, 06:13:00 PM
by 79coyotefrg
Last post Dec 19, 2009, 08:40:53 PM
by zippo
Last post Aug 18, 2014, 03:26:01 PM
by yotadork83
