Winch problems, m8000
Started by junya92toy, March 08, 2011, 02:34:13 PM
junya92toy
So its not working, I can hit the button and the soleniods just click. I took everything apart there and cleaned them up, nothing. I then took the power cable, and connected to it f1, and hooked the f2 and a wires together, nothing. Bad motor? Before I took anything apart, when hitting the button, with a test light, it showed power at all the terminals.
yotaneck13
did you actually pull the motor apart and check all the brushes?
junya92toy
Muddytazz
If your solenoids are clicking, then there is your issue.  Replace them like I told you earlier lol
Build it right or get off the trail
junya92toy
SHouldnt the motor turn over if I tried to bypass them?
79yota4x
my dad had to replace the motor on his, it was under water quite a bit though :ack:
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
Muddytazz
The motor will only turn over if you completely bypass all 4 solenoids
