Author Topic: Warn M8000  (Read 6551 times)
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Warn M8000
« on: Mar 01, 2011, 08:49:38 PM »
I didn't want to thread jack so here's mine:
I bought this winch to replace the SmittyBilt I had, just trying to assure myself that I made the right choice.
Thought about the Warn Tabor 9K, then said to myself, it's a Toyota...8k is plenty. Any feedbacks woulod be great.
 M8000 Self-Recovery Winch
 M8000 Self-Recovery WinchRated Line Pull: = 8000 lbs.
 Motor: = 12V
 Horse Power: = 4.8
 Remote Control: = Remote switch, 12 ft. lead
 Gear Ratio: = 216.1
 Size: = 21.04 in. x 6.3 in. x 7.6 in.
 Weight: = 80 lbs.
 Wire Rope = 100 ft. of 5/16
 Fairlead = Roller
Muddytazz
  • Turtle Points: -10
  • Male Posts: 396
  • Member since Jan '11
  • I hear voices in my head!
Re: Warn M8000
« Reply #1 on: Mar 01, 2011, 08:56:23 PM »
Post a pic of it....but yeah they are very good winches
Build it right or get off the trail
LD
  • Turtle Points: -2
  • Male Posts: 286
  • Member since Feb '10
Re: Warn M8000
« Reply #2 on: Mar 01, 2011, 09:01:59 PM »
I will tell you what you want to hear. You made the right choice. That is a great winch. Im just too cheap to spend alot on something i never really use
The best place to find a helping hand is at the end of your arm.
Muddytazz
  • Male Posts: 396
Re: Warn M8000
« Reply #3 on: Mar 01, 2011, 09:10:32 PM »
I'll also tell you a little unknown secret.....Warn's winches are severely underrated.
yoshaleng [OP]
  • Male Posts: 1,258
Re: Warn M8000
« Reply #4 on: Mar 01, 2011, 09:16:43 PM »
The smittybilt that I had before did great until I pulled a chevy 1500 at hollister, after that...it just wasn't the same anymore. The lever would disingage on it's own and the lever became sloppy. I was going get the MileMarker 10k but the guy said between SmittyBilt and MileMarker...he has more issues w/ mile marker.
That's true and I use think the same thing but this time I want to make sure the lever won't disengage while in action.
« Last Edit: Mar 02, 2011, 06:13:03 AM by YosHaleng »
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
Re: Warn M8000
« Reply #5 on: Mar 01, 2011, 10:01:25 PM »
it's a great winch and so is the taabor 9k thats what i have and i like it work for my 4runner that weighs 5999lbs
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: Warn M8000
« Reply #6 on: Mar 02, 2011, 01:21:18 PM »
Great winch.  I've got the same one.  I've had a couple hard pulls on it with no issues.  Several wheeling buddies have M8000's as well with no issues.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
AfflictedPast
  • Turtle Points: -3
  • Member since Feb '11
Re: Warn M8000
« Reply #7 on: Mar 03, 2011, 08:28:33 PM »
I run a m8000 with syn cable and like it a lot. tons of guys run em with zero problems, simple and reliable
yoshaleng [OP]
  • Male Posts: 1,258
Re: Warn M8000
« Reply #8 on: Mar 03, 2011, 10:43:05 PM »
who's synthetic rope did you go with and why them?
ADIDA4X4
  • Turtle Points: -2
  • Male Posts: 18
Re: Warn M8000
« Reply #9 on: Mar 07, 2011, 05:11:30 PM »
I know that once I got my 8274 I used it for everything. I attached a block to the rafters in the shop and took a body off a pickup, hauled in a couple logs, I even righted a flopped forklift. You can do anything you can think of with a good winch.
Get a good one though cuz I had a harbor freight and lost reverse (power out).
85 4wd 22rte puzzle
Thomas P
  • Turtle Points: 109
  • Male Posts: 3,092
  • Member since Feb '06
Re: Warn M8000
« Reply #10 on: Mar 07, 2011, 06:06:17 PM »
ive got 2 of them and they are great, they get tons of use also, pulling out  OTHER vehicles of course......
'14 Camry SE
SCX10 Honcho on roids!
redrocket93
  • Turtle Points: 3
  • Male Posts: 690
  • Member since Mar '06
Re: Warn M8000
« Reply #11 on: Mar 08, 2011, 08:12:18 AM »
I've got a Warn M8000 with amsteel synthetic rope. Used it many times in the past few months and am very happy with it. Simple and reliable. I had a POS harbor freight winch before. It was junk after using it a handful of times. Get the M8000 you won't regret it. Warn describes the Tabor as there values series, entry level winch. I don't like the sound of that.
Muddytazz
  • Male Posts: 396
Re: Warn M8000
« Reply #12 on: Mar 08, 2011, 08:14:54 AM »
The Tabor winch is designed as a light duty winch.  There is nothing wrong with them at all, just no practical use in the offroad industry IMO.  It was actually designed for the farmer in mind.
79yota4x
  • Male Posts: 127
Re: Warn M8000
« Reply #13 on: Mar 08, 2011, 09:04:00 AM »
Great winch, had one, rule number one never wheel alone, or without a winch :)
Get oN iT anD Stay on iT
79 pickup doved, locked, half cage, boggers
88 ext pickup linked with fox airs up front, 39.5 iroks,Beadlocks, 5.29s, 4.7s, chromolys, 6shooters, hp arb,  spool and 56 chevys in the rear
yoshaleng [OP]
  • Male Posts: 1,258
Re: Warn M8000
« Reply #14 on: Mar 08, 2011, 10:12:48 AM »
 :yesnod:
AfflictedPast
  • Turtle Points: -3
Re: Warn M8000
« Reply #15 on: Mar 16, 2011, 12:30:50 PM »
Sorry for the late reply... i went with amsteel blue from customsplice.com. mainly because of good reviews and the great deal i got from them on pirate forums for rope/crush proof thimble/upgraded hook and rock sleeve.
yoshaleng [OP]
  • Male Posts: 1,258
Re: Warn M8000
« Reply #16 on: Mar 16, 2011, 09:59:52 PM »
thanks for the reply, I'm thinking about ripping out my cable and replace it with synthetic rope.
toygasm
  • Turtle Points: 31
  • Member since Dec '08
Re: Warn M8000
« Reply #17 on: Mar 18, 2011, 09:31:19 AM »
which is better..warn 8000 or tabour 9000?
« Last Edit: Mar 18, 2011, 10:04:15 AM by toygasm »
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
Re: Warn M8000
« Reply #18 on: Mar 18, 2011, 10:50:42 AM »
Warn M8000.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
toygasm
  • Turtle Points: 31
Re: Warn M8000
« Reply #19 on: Mar 18, 2011, 11:34:56 AM »
thats what i thought.ive got a brand new tabor 9000 and my brother is giving me a new 8000lb warn he isnt going to use now.both are unused.i was just wondering which one to keep and which one to sell.. :thumbs:
Jaysen
  • Turtle Points: -20
  • Male Posts: 773
  • Member since Mar '08
Re: Warn M8000
« Reply #20 on: Mar 18, 2011, 12:51:37 PM »
keep m8000! I just got one from my uncle who work for WARN! I got a STEAL ON MINE!  :yesnod:
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
yosh
  • Turtle Points: -12
  • Member since Mar '11
Re: Warn M8000
« Reply #21 on: Mar 18, 2011, 01:48:00 PM »
self recovery huh?
Thomas P
  • Male Posts: 3,092
Re: Warn M8000
« Reply #22 on: Mar 18, 2011, 10:18:55 PM »
They must have thought they were getting installed on Jeeps only......
self recovery huh?
'14 Camry SE
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
Re: Warn M8000
« Reply #23 on: Mar 21, 2011, 07:19:44 PM »
I love mine.  I have been around the smittybuilt and the mile markers and they all seem to crap out with a little abuse, at least the ones I've been around, but my warn is still running like new after 7 years.
I do know some guys have good success with the cheaper winches but I would rather buy it once and be done with it.
Last post Oct 12, 2004, 06:46:33 PM
by UNBREAKABLE
Last post Jul 07, 2006, 09:02:42 AM
by burnyota
Last post Sep 01, 2009, 09:15:13 AM
by Yotaman80
Last post Apr 26, 2012, 12:31:50 AM
by 86yoter
Last post Jul 06, 2014, 10:43:48 PM
by Slolyfe
