Author Topic: I need your opinions  (Read 3509 times)
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
« on: Feb 26, 2011, 10:07:26 PM »
Should I wait for Marlin to get restocked on their 4.70's or should I just buy one of his crawl boxes and sell my current rear t-case? Thanks in advance.
jackson58
  • Turtle Points: -1
  • Male Posts: 77
  • Member since Jun '09
Re: I need your opinions
« Reply #1 on: Feb 26, 2011, 10:20:49 PM »
Not that you could not put it together youself correctly but if you bought one from Marlin you know it is going to be correct. Also if you have a problem it wil be easier to take care of since you can't be blamed.
Dirt is for wheelin not for wearin you filthy hippie!
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Member since Mar '10
  • Honey Badger
« Reply #2 on: Feb 26, 2011, 10:21:36 PM »
So you're talking about getting a crawl box from him with 4.70?
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #3 on: Feb 27, 2011, 12:06:36 AM »
yea, thinking real hard about getting one of his crawl boxes as my rear tcase with Davez off road's twin stick conversion.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #4 on: Feb 27, 2011, 12:09:11 AM »
they have some one setting up gears that has no clue what their doing so you would be better setting them up your self. read the threads about the tranny problems people are having. not knockin on them but they don't really have any quality control now a days.
86 mini truck 18" rays
09 highlander
70 suburban
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #5 on: Feb 27, 2011, 12:50:10 AM »
Are you refering to Marlins crawl boxes?
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #6 on: Feb 28, 2011, 03:45:24 PM »
damn...now you got me thinking Fade.
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« Reply #7 on: Feb 28, 2011, 03:49:24 PM »
Its an easy set up. Save your money and wait.
PZ
Hemenechi
  • Male Posts: 13
  • Member since Feb '11
« Reply #8 on: Feb 28, 2011, 04:07:34 PM »
do you really need to do the 4:70 now? i would just send them a message to get atleast an idea of when they will be back in stock. if its not to long and you can wait... then do so and save some coin. if its going to be a while maybe then you could do the crawl box idea.
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Crawlin with Marlin
« Reply #9 on: Feb 28, 2011, 04:21:18 PM »
Do you have duals now?  You'll want the 4.70 gears in the rear case for durability.  If you already have duals you might as well wait if you're confident in your skills.  You won't gain that much in wheeling if you already have duals.  If you have a single stock case then it might be worth getting it now if you have some wheeling trips planned that you would miss out on by waiting.
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #10 on: Feb 28, 2011, 04:33:11 PM »
yeah, I'm currently running dual stock cases w/ twin sticks conversion in the rear case for about 2yrs and it has done me alot of justice so far.
  • Male Posts: 5,060
« Reply #11 on: Feb 28, 2011, 05:46:06 PM »
In my opinion you don't NEED lower gears so I'd wait until you can get the best price IF you're capable of doing the install yourself.  I'm not so I purchased a full 4.70 rear case and ran a single 4.70 case for several years.  You'll love the lower gears, but I've found that the most useful gear is really 1st gear in 4.70 low which should be similar to low-low in a stock double case configuration.  The lower gears often don't have enough momentum for climbing.  My experience is almost all in Moab so it likely doesn't apply to all wheeling.
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #12 on: Feb 28, 2011, 10:04:09 PM »
called Marlin today and the earliest delivery will be in middle of Aug.
83 Crawler
  • Turtle Points: -13
  • Male Posts: 2,779
« Reply #13 on: Feb 28, 2011, 10:06:31 PM »
 :yikes: thats a long wait!!
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #14 on: Mar 01, 2011, 09:57:44 AM »
buy them from someone else then..thats way too long of a wait..there a pretty basic install!!
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #15 on: Mar 01, 2011, 10:58:20 AM »
called every where....Low Range, Davez off roadand even TG is Out of Stock. Nodbody has just gears in stock, only crawl boxes.  :willynilly:
pistolbob
  • Turtle Points: -1
  • Male Posts: 17
  • Member since Jul '10
« Reply #16 on: Mar 01, 2011, 11:42:31 AM »
Have you looked for used 4.7's or a used t-case with 4.7's in all ready? That's how I got mine. $250 for rebuilt transmission and 4.7 transfer case.
  • Male Posts: 5,060
« Reply #17 on: Mar 01, 2011, 11:45:23 AM »
Here's how I'd make the decision.  First, you have to determine how much benefit you're really going to get from having lower gears and how much of it is a bling factor.  With dual cases you have plenty low gears for most wheeling.  Second, you need to determine how much your time is worth on this project.  If you're not familiar with the gear install it'll take you a few hours to do the swap and there is always a risk that you could do it incorrectly.  I know that part of the install is clearancing the case housing for the larger gears and this could take some time using the trial and error method.  Third, is the $225 difference in cost significant for you?  Will it squeeze your budget significantly and/or prevent you from purchasing something else that you need or want?  Finally, you have to combine these things and make a choice before the assembled cases are also out of stock.
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
« Reply #18 on: Mar 01, 2011, 11:55:37 AM »
Then don't wait. If you wait, it'd be like saying, "Oh that's fine that you don't have yet another part in stock Marlin Crawler, I'll just wait half a year because you can't keep stocked shelves."
I work a 2000 BMW 540i 6 speed
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #19 on: Mar 01, 2011, 06:27:31 PM »
good point....I'm changing out my clutch so that's why I want to put in the 4.70 now since I have to take off the t-case anyway. My trucks going to be out of commission for a couple of days due to multiple upgrades. To think about it, It won't be a major gain due to current setup up but having that security blanket as a rear case always helps.
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #20 on: Mar 01, 2011, 06:40:40 PM »
I was leaning towards that way but BlackDiamond brought up some good points. Not only that but loosing my rear t-case as a core will hurt due top shift conversion kit, twin sticks (but that will be reused) and paid 100.00 for the tcase.
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #21 on: Mar 03, 2011, 11:51:06 PM »
finally got my Marlin 4.70's, thanks for your inputs.
91 ex-cab
  • Male Posts: 1,660
  • Honey Badger
« Reply #22 on: Mar 04, 2011, 09:37:19 AM »
23 or 21 spline?
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #23 on: Mar 04, 2011, 12:43:52 PM »
Got 21 splines.... Gonna buy Marlins rear output shaft kit instead of 23 spline coupler
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #24 on: Mar 08, 2011, 11:44:50 PM »
went back and exchanged for 23 splines and picked up MC07 non-rotated.
4Runner_guy
  • Member since Jan '11
« Reply #25 on: Mar 11, 2011, 06:56:13 PM »
Save your money and just wait cause it'll be worth your while.
yoshaleng [OP]
  • Male Posts: 1,258
« Reply #26 on: Mar 11, 2011, 07:06:54 PM »
zuluzeugma
  • Turtle Points: -1
« Reply #27 on: Mar 16, 2011, 07:01:22 AM »
dont wait. buy now
cztheman64
  • Turtle Points: -3
  • Member since Dec '10
« Reply #28 on: Mar 16, 2011, 06:32:18 PM »
get it set up... its a lot easier!
yosh
  • Turtle Points: -12
  • Member since Mar '11
« Reply #29 on: Mar 18, 2011, 02:04:17 PM »
x2. don't get the china gear junk.
Last post May 22, 2004, 09:31:09 PM
by Hyena
Last post Jan 29, 2005, 06:33:47 PM
by Skinny_Pedal
Last post Feb 11, 2005, 10:35:05 AM
by BLUCRUZ
Last post Dec 20, 2009, 11:46:38 AM
by NCK4L
Last post Oct 21, 2011, 03:16:17 PM
by BadnewsBob
