The whole reason I've thought to rotate the perches is to fix my caster angle(I want my knuckle to look like it's just about sitting level). If i cut off the perch and reposition it so that my caster angle is correct, I'm not seeing why repositioning the knuckle location would be necessary. I'm using the perch rotation to fix the knuckle angle.
With the cut and rotate, you are correcting two things caster and pinion angle, if you just cut the perches and relocate them for better caster your pinion angle will suffer.
Jake, so you didn't use any shims on your perches? And you didn't modify your perches or knuckle balls in any way?
Ok, so just to clarify the things you guys have said----If i relocate the perches and fix my caster angle, i just need to make sure the pinion angle is ok as well. If i relocate the perches for good caster and it just so happens that my pinion angle is alright too, that's all good, RIGHT?
Started by toymachine General 4WD Discussion
Started by ccannon222 Engine
Started by Northern Runner Engine
Started by birfection Engine
Started by NorthBayCrawler Newbie Questions
