Rock light install
Started by Yota4life, January 16, 2005, 01:19:37 PM
SWAMPER
lilbuddy
awesome, those look really good on there  :yesnod: Do you actually notice a difference with the silverstars?
Chris
RIP Kyota.... you are the man
GET IT!!!
SWAMPER
Yup they are "brighter" or "whiter" dont know...but they arent as "yellow" as normal ones....get me :headscratch:
Yota4life
Quote from: lilbuddy on January 17, 2005, 09:01:37 PM
Chris
Yeah they are way bright. And Whiter. I noticed a huge difference.
Chris you should mount your rear rock lights on the body mount in front of the rear tire facing down like mine, they will make way more light.
SWAMPER
I will be doing this soon too....a lot more lights for Swamp I belive :yupyup:
Yota4life
Swamper when you going to SAS and all that good stuff?
SWAMPER
Patience is the key to.....Just hold your damn horses boy....remember...No rest for the wicked! (Mr. Burn's voice) Excellent!
lilbuddy
I might. I also might just go and pick up another 2 and use them behind my rear tires. Kind of an over kill but oh well. Theyre only 55 watts so it isnt that much power drain from my alternator. I might get some silverstars once I buy other things for my truck. I used the screws that came with the lights in the back lights and they are like woodscrews :slap: I dont know what I was thinking but they are in nice and tight.
Chris
GET IT!!!
Just think, for every 10 watts you are drawing about 1 amp from your charging system.  Not a big deal till you add up everything.  One 55 watt light is 5.5 amps of draw.  Multiply that by 4 you get 22amps.  If you put 6 lights on there it would be 33 amps.  You might wanna check out what your alternator puts out before you go too overboard.
lilbuddy
Cant forget my KC lights, stereo, 450 watt AMP, headlights, dash lights, tail lights, side markers and 4 rock lights... I think i have a 90 amp alternator but I am not sure. I probably should check into my charging system before I put anything else on my truck. The volt meter gauge doesnt go down that much when all that crap is on though. Next thing that I MIGHT do is another set of KC's. Thanks for the heads up White Trash.
Chris
GET IT!!!
mudaddict
#40
White trash what kind of lights did you get?? i jsut picked up from my work 4 lights that hella makes for tractors and heavy duty stuff! i will be mounting them on thursday and with that will come pics i am also installing a 120 amp alt! i will then have a total of 12 lights!  :dunno:
I work At
All Pro Off Road
Ive got a pair of lightforce lights on the front on the winchmount.  I used 6 typical 35 watt tractor lights, 2 of the same wal-marche` superwhite lights  over the front tires but they are getting remounted beings you can still see them.  I also have 2 TINY pilots in the rear by the axle.  Ill be adding a few more sets for different situations in the next few weeks.  Im not too worried about over running my charging system beings I never run all the lights at once.  Im pretty sure once its all done I could hit all the swithces and the truck would shut off. :gap:
mr4x42u
I have one in each door and one pointed at each drive line ..I really like the door lights.had doubts at 1st .There handy and protected..fun to have also..they can fold down for more light down or out more from inside the rig..
I want them in my full doors now,,but the window is in the way.
Volcom
I just picked up some cheap fog lights at Harbor Freight.  They are 55 watt, H3 bulbs (upgradeable to 100W).  One pair cost me $8  :thumbs:   They are rectangle and a little bigger than the ProBurners used at the top of the thread.  Should work great for rock lights  :usa:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
KYOTA
Yota4life
The light in the door is a good idea. Those Hella lights are a great deal at only 9$ each. My wallymart lights are doin good but one filled up with water but i got it all out. Its all good. I might put more on later but i dont think i need anymore.
FATB0Y
mudaddict
ya the lights in the doors are a really good iead! ya i couldnt resist it! any of the local schucks kragen or checkers can order them jsut have them look em up in the catalog!  :thumbs:
I work At
All Pro Off Road
fuglytruck
kinda alot of input already in but ill add my 2 cents also.... im running the same damn lights in the front under my fenders and in  the rear under my flatbed,,, also running two other 3 inch 4 inch round lights aiming strait down for light if i break at night..   helps to add a light under the hood..   just an idea   and if u do do it   make sure u run some kinda on off switch under the hood...
also one more big thing......MAKE SURE U DONT GET THEM LIGHTS WET WHEN THEY ARE ON OR HOT.. THEY WILL CRACK.. TRUST ME    I KNOW FROM RUNNING THRU RIVER CROSSINGS
i just cut a guys 4x4 in half and he didnt even put up a fight.
FRENCHBLUE72
I bought some of em and shattered the glass lenses first rip out.. The really do need a guard or cover for them to last long.. Looks good as rock lights mine were pointed forward..
82 YOTA
Yota4life
My front ones keep filling up with water. I thought i had them water tight. O well i will just empty the water out once i go night wheelin.
lilbuddy
Mine are doing good now. They stopped fillin up with water so Im good there. Its their design and since they are cheap im sure thats why it fills up. My KC lights dont get any water but they are a high quality and dont see as much water as the rocklights do though.
GET IT!!!
Yota4life
I think the only spot the water is getting in is where the cables go into the housing. Im going to fill that with silicone.
dirtbag
how many watts are a set of stock sylvania headlights? I have 2 to 3 pairs lying around, and, since I'm REALLY cheap, I was thinking of using them for rocklights. Any info, input, STFU DB comments?
FATB0Y
dirtbag
Quote from: WHITE_TRASH on February 09, 2005, 12:42:52 AM
STFU dirtbag. :hahaha:
thank you, now how about some real information?
DB= :slap: =WT
Skinny_Pedal
Im an OG
Generally halogen neadkights are 55 watts on lowbeam and 60-65 on hihg.
mudaddict
they are 55 low and 65 high!
I work At
All Pro Off Road
