because we all know you can find something bad about anything online.
well fist off if you have ever done lots of bend test you'll know that its almost impossible to crystallize steel using a standard mig process, you would realllly have to do something wrong, if anything its gonna be something along the lines of incomplete pen, contamination, or porosity. second off i don't know where your getting a 6mm open root bend test from? i would love to see someone successfully do that properly with mig, not saying it cant be done but that's not right. unless im reading your info wrong. and when you say "5 passes as such", then do a picture that has 11 passes! i dont get itthird off most every machine that's remotely modern has an auto shut off when duty cycle is exceeded, so you cant damage the machine. fourth it would be nearly impossible to burn up a tip/nozzle/or gun using mig. if you convert your machine to spray (not pulse spray but just spray) it happens all the time. or if your tig welding without the right size torch or style of torch, etc then yes it happens. but for you to do damage to what your stating i would have to hook up a 110v gun to a 220 machine and weld continuously with high amps.fifth I wouldn't attempt a proper v-grove weld in 1 of 2 passes on 3/8s plate with a 110 welder but i sure as hell can do it properly with 4 passes. i dont know where some people get the idea that a 110v couldnt properly do a beveled full pen weld. dont get me wrong though, im not talking about industrial welding of 1/2 thick material, or grove welding all day. using a 110 would be a joke.
I didn't think this thread would have so much confrontation.....thanks for your advices.
Did you figure out which welder yo are going to get ?
Wow, I didn't think I would get this much info with thread. Thanks again. Im gonna go get me that Miller 211 so I have the option to go back and on the voltage needed.
yes....going with a miller 211,,,not exactly the cheapest in price but it allows me to change from 110 to 220v when needed. miller 211 with 40lb tank for 1175.00
Started by phlatbed Parts Wanted
Started by 89 toy Chit Chat Camp
Started by oddball Chit Chat Camp
Started by h0nke General 4WD Discussion
Started by 86turboyota Bumpers, Cages, and Tube Benders
