Author Topic: 20r/22r/22re Frankenstein  (Read 2657 times)
blackxlava
  • Turtle Points: -1
  • Member since Jul '07
« on: Dec 15, 2010, 07:45:36 PM »
so I've acquired a 20r('79), a 22r('84 early), and a 22re('87) engine. all ran when pulled. my question is, what do i use to get the best performance in one engine? I've read about using a 20r head on the 22r block, but is that the early block or the 85+ block that has a shorter deck height? or using the the flat top pistons or the stocked domed?
as it sits i have a lc .450 cam, adjustable cam gear, 4barrel offenhouser intake(22r), 2 barrel offen. intake(22r), pacesetter header, and some other little odds and ends. all the engines are complete.
also does anyone know if there is a difference between the 20r's heads or are they all the same?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 20r/22r/22re Frankenstein
« Reply #1 on: Dec 15, 2010, 08:11:28 PM »
use the 20R head and intake on the 22R(81-84) block.  nothing from the 87 22RE can be used unless you need the crankshaft
some EARLY 20R's had smaller combustion chambers but those usually did not have mounts for pwr steering
Use the 79 20R you have.
sell that pacesetter on ebay, its worthless unless its a rare long tube (Ive never seen a long tube Pacesetter)
use the 22R carb on the 20R intake.
if you cant afford a good header run a 22R exhaust with the long twin tubes down to the cat then a 2 1/4 inch tube to the rear
blackxlava [OP]
  • Turtle Points: -1
« Reply #2 on: Dec 15, 2010, 08:56:38 PM »
actually its a long tube, didn't think it was rare. and I'm guessing sell the intakes for the 22rs and the 22re?
can i use a 32/36 Weber currenting on the 22r? or do i need to find a stock one for the 20r?
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #3 on: Dec 17, 2010, 12:58:32 AM »
Whats wrong with a pacesetter header? I love mine. I've seen nothing but bad come from hooker headers and lce ones are alot of pennys.
86 mini truck 18" rays
09 highlander
70 suburban
Last post Dec 12, 2005, 10:17:41 AM
by BoG-ToY
Last post Mar 02, 2008, 09:28:11 PM
by pyrosnow911
Last post May 02, 2009, 04:31:17 PM
by AaronB
Last post Jun 20, 2014, 10:14:17 PM
by DakotaRT
Last post Aug 27, 2015, 03:19:23 PM
by jangelfire
