What is the carier break in a Toyota?
Started by 86yota, January 05, 2005, 07:16:45 PM
86yota
Just like the subject says.  Or is there even one?
brainlessfool
86yota
So I can put 5.71s on the same carier that had 3.90s stock?
KYOTA
#5
oh your talking about the 'break' in ratio that you can put on a carrier . you can but you dont want to 5.71's are weak sauce
Mike D
go with a 5.29 if ya offroad but if not just get 5.71
BCD
The 5.71's are more low than most people would need, the problem is that in order to create such a low gear ratio the ring gear gets reletively strong, however the pinion is very very small...leading ultimately to easy breakage. Some people say the 5.29's are even too weak, but I and many other people run them with 37's and larger. Hope this helps.
reklund5
Good info there BCD!  :beerchug:
I see your jedi training is coming along nicely!  Are you going to Chili Challenge or what?
Ryan
86yota
Thanks for the info.  BTW I dont actually plan on running 5.71 gears, I just threw that out there for the sake of the conversation.
