Author Topic: v6 axle  (Read 2576 times)
0 Members and 9 Guests are viewing this topic.
YotaTodd
  • Male Posts: 68
  • Member since Dec '09
v6 axle
« on: Dec 07, 2010, 10:58:47 AM »
quick question how strong is a 97 4runner rear axle? i herd 4cyl axles r good it'll 37's.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: v6 axle
« Reply #1 on: Dec 07, 2010, 11:37:26 AM »
Ive only ever heard of ONE person that broke a rear axle shaft,  and he was standing up a very steep incline and at full throttle bounced on the right rear tire.  dual cases and 37's,  something had to give and it did.
under 99% of wheeling you'll never brake a rear shaft
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: v6 axle
« Reply #2 on: Dec 07, 2010, 12:42:57 PM »
Well now you have heard of another two. First picture is a stock, the seconded is a Poly Performance alloy axle that I broke in two places.
I ran a 4-cylinder, ARBed, Genuine Geared diff on 37 MTR's & BFG's in the rear for many years with out a problem. V-6 or late model diffs (the four cyl in later years are the same as the V-6) are a bit stronger but IMHO not enough to worry about.
YotaTodd [OP]
  • Male Posts: 68
Re: v6 axle
« Reply #3 on: Dec 07, 2010, 02:16:11 PM »
thanks for ur help
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
Re: v6 axle
« Reply #4 on: Dec 07, 2010, 11:13:12 PM »
According to ZUK the V6 3rds are 10 percent stronger due to the slightly larger carriers bearings (5mm bigger). The axles are the same between 4 cylinder and V6.
YotaTodd [OP]
  • Male Posts: 68
Re: v6 axle
« Reply #5 on: Dec 09, 2010, 09:42:14 AM »
i think I'm going to put the 97 3rd in my 82 axle because the 97 has a limited slip and 488 gears.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
Re: v6 axle
« Reply #6 on: Dec 09, 2010, 02:01:13 PM »
Ive seen 3 break on the trails.
You'll never take me alive
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
Re: v6 axle
« Reply #7 on: Dec 09, 2010, 02:19:07 PM »
FROR full float rear!
If you see it, its for sale.
tanabuse
  • Turtle Points: 4
  • Male Posts: 185
  • sleeper, any time any trail any where
Re: v6 axle
« Reply #8 on: Dec 14, 2010, 10:28:09 PM »
so how much bigger is the lower pinion bareing the a 4 banger i hurd something like 40 %larger
Turning
Over after
Years
Of
Trail
Aabuse
dirtchicken
Re: v6 axle
« Reply #9 on: Dec 14, 2010, 10:45:44 PM »
YotaTodd [OP]
  • Male Posts: 68
Re: v6 axle
« Reply #10 on: Dec 15, 2010, 11:24:22 AM »
 :yikes:
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
  • Member since Dec '06
Re: v6 axle
« Reply #11 on: Dec 22, 2010, 04:12:34 PM »
Thanks for the pic. i have allways been curious on the bearing sizes.
zippo
  • Male Posts: 1,557
    • oppiz.net
Re: v6 axle
« Reply #12 on: Dec 22, 2010, 04:31:47 PM »
You can run V6 gears and what not in a 4cyl housing, Just need the right setup kit which has odd in the middle bearings.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: v6 axle
« Reply #13 on: Dec 22, 2010, 06:23:05 PM »
nope, u use the 4 cyl gears in a v6 housing/carrier with v6 bearings, u just need to shim the pinyon alot more, there is a writeup about it on zuks gear install's page
http://gearinstalls.com/cus.htm
Last post Dec 13, 2005, 10:19:37 PM
by DRM
Last post Mar 03, 2006, 05:44:55 PM
by KYOTA
Last post Aug 11, 2008, 02:39:37 PM
by cruiserfj45
Last post Sep 28, 2008, 07:18:11 PM
by sandboxtoy
Last post Sep 29, 2009, 09:02:10 PM
by 79coyotefrg
