Toyota Solid Axle Widening Kit
Started by gmrwizard, January 04, 2005, 10:12:34 AM
gmrwizard
I just found this kit. Sky-Manufacturing. Anyone tried it out yet? What IFS hubs will work on the solid front axle?
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Doing 88 Toyota 4X4 (Desert race truck)
Next 81 Toyota 4x4 (drive train upgrade)
Are you talking about their spacer kit that we are talking about over here?
awhotrods
That looks pretty interesting, has anyone used it??
ZaCk'S 83
if u want to widen ur solid axel i would just put wheel spacers in the front and then in the rear put an IFS rear end housing.there 3 in wider so u put 1.5 wheel spacers on each side
I wont run spacers on anything I drive.  Its not that they arent safe by any means, its just personal preference.  I used 94 ifs hubs, 78 cruiser rotors with 94 calipers.  I moved the caliper to the frontside of the knuckle.
jayson161
im running sky's axle widening kit right now, i heard to many horror stories about running wheel spacers. i used my manual hubs and ifs calipers from my 94 and used marlins vented rotors. turned out pretty nicely
Huhwhye
I refuse to run spacers also.
I am planning a SAS on my 87 Turbo Truck and am looking for options.  Since I don't have a Toy front axle yet I am open to suggestions.  But I will not run spacers.
'04 Taco DC 4x4
bkg
Quote from: Huhwhye on January 09, 2005, 11:46:04 AM
Curious wy people refuse to run spacers...
Im too lazy to take the tires off and check the torque on yet another set of lugnuts, I check my lugnuts often enough but I dont feel like taking the tires off to check the other ones.  Well that and Ive much better things to spend my $$ on.
Huhwhye
What he said.  Its an extra link in the chain, 1 more point of failure, 1 more thing to keep an eye on.  There's a reason no racetrack with let you run spacers, I know must of us don't race our trucks.  But in the drag, road, and autocross racing worlds spacers are not allowed as a safety precaution.
And on top of all that, it's cheesey.  No offense to anyone, but it is.
'04 Taco DC 4x4
Volcom
Quote from: Huhwhye on January 09, 2005, 09:02:19 PM
I've seen tons of guys run spacers in the autocross world (Honda Civics and Acura Integras running really wide 13 inch wheels and race rubber).  Once again, you have to check them offen and get the proper torque on them.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Huhwhye
#11
OK whatever, maybe I'm wrong.  Maybe you can use them in limited scenarios.  But I still wont run spacers on anything I own.  Cheesey.
'04 Taco DC 4x4
awhotrods
So it sounds like the sky kit is the way to go, I put a 88 rearend in my 82 4WD and the front looks stupid because its so much narrower than the rear.  I need to fix it!   :ack:
bkg
I can buy the "don't want to constantly have to check torque" on wheel spacers... Makes sense.
Keep in mind that Sky's kit is behind the hub - between the hub and the rotor.  Should be no need to constantly check torque as they are not subject to the same stresses as hub-based spacers.  Put some red-locktite on them and forget 'em.
I run the 3/4" spacers on both of my trucks w/ no problems.  Not ideal, I agree, but never been a problem.  If I had an unlimited budget, I'd run an FRORF front axle to eliminate the need...
gmrwizard
QuoteI'd run an FRORF front axle
OK, taint never heard this one before, what is it?
camo89
ILL SAY THIS LOUD THE SKY KIT SUCKS ASSSSSSSSSSSSSSSASSSSSSSSSSSASSSSSS HAD IT BROKE IT AND I DIDENT WHEEL THAT MUCH
mopar parts
awhotrods
What is that???
94toytruck
i have the sky widening kit.works great. i used my stock 94 4x4 wheel hub,widening kit,fj rotors,stock calipers. havent had any trouble with anything.
how the heck do you break this??? its pretty much a solid peice of steel. it holds almost no load besides for braking.
95 x-cab truggy, 39 pitbull's on KMC's and 60/14b with chromo's, ultimate duals, linked and Co'ed
www.rightcoast4x4.com<<<get it
FRORFab
Quote from: awhotrods on January 12, 2005, 01:08:37 PM
What is that???
Soryry, not anymore.  Because of spacers becoming cheaper and much higher quality (rare occurance).  We discontinued our Wide kits a few months back.  Oursa ran 299, but was machined in one setup, perfectly concentric, perfectly parrallel.  We also include bushings to shim from the 15mm hole in the rotor to a standard size for a no slop fit.  If you want you rotors located radially, and have all the braking/shearing force on 2 pins, and undersized bolts, go for it.  Ill take some red loctite, and decent spacers any day over that!
bkg
Quote from: FRORFab on January 15, 2005, 10:44:59 AM
Brian, can you elaborate on this some more??
My original comment was directed at the FRORF housing - it's beefy and definitely part of the "ultimate toy front axle" consideration.
Link: http://www.frontrangeoffroadfab.com/front_axle_housing.htm
Beef, and custom widths available that allow you to match the width of the rear housing.
