Author Topic: drum brake fitament  (Read 2216 times)
SpencerS
  • Member since Oct '10
drum brake fitament
« on: Nov 25, 2010, 07:34:19 PM »
Hey guys
For yhanks giving i got to rebuild my rear brakes. I am having a problem getting the new drums to fit on the assembly after putting new shoes and wheel cylinders on. The e brake is not engaged at all because the lever is fully in the back position.
I have yhe adjustter set to pull the shoes in all the way to the minimum.
Any ideas?
They are all napa parts
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: drum brake fitament
« Reply #1 on: Nov 25, 2010, 07:55:30 PM »
Shift the shoes up and down until the drum fits............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
SpencerS [OP]
« Reply #2 on: Nov 25, 2010, 08:48:39 PM »
Tried that already. Ive moved all the components around to check if any were binding up. Even took it all apart and put it back together.
Im stumped
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #3 on: Nov 25, 2010, 08:55:30 PM »
Pics ?  Your saying the drum does not go back on, with the adjuster backed off and everything is the way it should be ?  Did you try rotating the drum all 6 possible ways ?  Maybe a warped drum ?  Wrong part ?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Nov 25, 2010, 09:23:11 PM »
post pics of your assembly sometimes a picture is worth a thousand words.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #5 on: Nov 26, 2010, 10:19:51 AM »
Had a buddy that had the same problem a few years back. On the aftermarket shoes he bought the slots for the e-brake bar was not deep enought. He got a set of OEM shoes and all was well.
SpencerS [OP]
« Reply #6 on: Nov 27, 2010, 06:04:17 PM »
so i got new shoes from napa and they fit now so thats a relief. but i have another question.
I put new studs on and the drum fits on the studs put theres a little bit of play left and right to make contact with the stud. Is that normal?
Do i have the wrong drum now too?
thanks guys
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #7 on: Nov 27, 2010, 06:17:53 PM »
A little play around the studs is normal.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
SpencerS [OP]
« Reply #8 on: Nov 29, 2010, 10:55:06 AM »
So now that everything is finished i have a leak some where that is sucking in alot of air because my rear brakes will not bleed theres so much air. Used 2 pints of brake fluid already. So now its a matter of tracing down the leak. Im pretty sure its the MC sucking in all the air. I will keep you guys updated.
Thanks for all the help guys!
SpencerS [OP]
« Reply #9 on: Dec 01, 2010, 09:24:43 PM »
So it was the master cylinder and my pedal pressure is descent now. But now the brake lights work some times and sometimes they dont. I think the sensor might have broke when i bled the brakes. Sigh.
Sonafter that its now time to track down a rear end vibration. I think its my damn ring and pinion.... Money pits are ftw but i still love my truck. But she gets to sleep on the couch for a few weeks. Haha
SpencerS [OP]
« Reply #10 on: Dec 02, 2010, 03:20:15 PM »
Yea so todays new problems are my battery either took a crap or my alternator shorted. And the only thing i can do now is laugh. Haha
SpencerS [OP]
« Reply #11 on: Dec 05, 2010, 12:43:53 PM »
Turns out that i just had bad contact with the terminals, cleaned em and everything is well. Also tightened up my driveline bolts(DERP!) and all vibrations are gone now! haha!
Last post Jul 10, 2007, 10:13:01 PM
by Joe S.
Last post Mar 21, 2011, 08:51:11 PM
by Burl
Last post Sep 04, 2011, 06:28:04 AM
by rock-smasher
Last post Mar 28, 2012, 12:12:36 PM
by SolidAxle
Last post May 18, 2019, 03:28:24 PM
by Toybrota
