high steer
Started by toyota41180, November 24, 2010, 06:57:00 PM
toyota41180
I was wondering how much lift you can put in a 1990 toyota pickup before the ball joints bind up and break
now this is what i got 1990 toyota truck rears up front 1 1/2 box drop and 6in shackles under the frame
Dog is man's best friend. If you don't believe me lock your wife and your dog in the trunk for an hour and when you open it see which one is truly happy to c.u.
yota4x4sc
like more then 10 inch springs
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
86bobbedtoy
how high you wanting to go?
yotatough
if your running high steer, then you should be fine
toyota41180
i  was thinking 5in springs in a rock crawler
86bobbedtoy
your good
I think 14" would be starting to get alot of bump steer.
a curved steering rod would help if going that high
I ran ruf,5"shackle in frame
on 42s maybe 7"-8" lift total including hanger
toyota41180
thanks guys i feel better
SCyotacrawler420
i would not go anything over 5 inch lift unless its a mall crawler, but if its a wheeler everyone says you can go with alot of lift, that is true if the springs dont flex, but a set of flexxy 5" springs might have harm on those tie rods, i know i went through at least a set of tie rod ends every 6 months cause flexing wears them out fast
yota4x4sc
Quote from: SCyotacrawler420 on November 29, 2010, 11:59:53 AM
na shut er down bro... look at the hawaii rigs.. they have smilie face leafs haha..theres handle
SCyotacrawler420
ya, handle on there sides in a rollover, an then once they get it back on there wheels they have to fix there TRE's, haha
