Which Tcase is driver drop?
Started by THK Matt, November 16, 2010, 08:56:27 PM
Okay so my question is...
Are there any chevy auto trans (5.7L V8) with driver drop tcases? or 5speed even..
Looking for an easy solution to be able to hook up a driveline to the ford high pinion driver drop D44 I have... Id rather not go with a pass drop low pinion D44 if I don't have to.
let me know... thanks guys...
BoG-ToY
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
 i dont know hardly anything on domestic tcases n transmissions... so i dont know what came on what or anything. So what did those come on and which vehicle, n year.
bigarms23
a np203 or 205, lomax tcase, stak box,atlas 2, taco box, offroad design tcase and im sure theres more
Dana 300 i was told.
I think i got an idea now :]
fade
should be 88-00 chevs had them. Ifs piles
86 mini truck 18" rays
09 highlander
70 suburban
Quote from: fade on November 17, 2010, 12:51:16 AM
Oh so if i find an 88-00 chevy with a 5.7L, 700r4/4L80e then im in business :P
yjay
Dana 300's came in early 80's Jeeps and 1980 Scouts. The scouts have a weird bolt pattern though(called Texas pattern)  By the time you flip it to drivers side which involves modifying the oil pump, etc., get a clockable adapter, and upgrade the relatively weak output shaft, you will be into it for a considerable sum. That's assuming you can find one. They are the coolest oe case around though when modded. Front and rear digs, regearable, huge gears. A friend of mine recently sold a flipped twin stick 300 he built but never used for over 1k.
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
BoG-ToY
gotta find one somewhere they dont know what it is...
BoG-ToY
HEY, you know what.. there is an old school 4x4 fool sized pickup in the local yard here?
You want me to check it out? get a quote?
Sure lol.
and if a can find a complete 88-95 Tahoe or Pickup.. then ill use the engine, trans and tcase. :P those have a 700r4 and 203? or 241?
From wikipedia
Transmissions:
    * Turbo Hydromatic TH-350 three-speed automatic (1973–1981)
    * Turbo Hydromatic TH-400 three-speed automatic (1974–1979)
    * 700R4 (4L60) four-speed overdrive automatic (1982–1991)
    * Saginaw SM465 four-speed manual (1973–1991)
Transfer cases:
    * Dana 20 - gear driven part-time four wheel drive (1973)
    * NP-205 - gear driven part-time four wheel drive (1973–1980)
    * NP-203 - chain driven full-time four wheel drive (1973–1979)
    * NP-208 - chain driven part-time four wheel drive (1981–1988)
    * NP-241 - chain driven part-time four wheel drive (1988–1991)
