front output shaft fix while still in truck?
Started by dirtclod01, November 11, 2010, 01:49:42 PM
dirtclod01
i need to put a new seal and bering on my front uotput shaft . can i do it without pulling the t case out?
my trucks a 85 4runner with a w56. shes pukin oil out the seal as fast as you put it in.
dirtclod01
can i pull just the t case or is it easyer  to pull the whole thing out togather?
mudmaster
Time to go wheelin!
dirtclod01
well i got it out. the inside looks like rusty chocolet milk . any good ways to clean it up? i'm doin this cheap!
swapped89
Tear it apart and clean everything with soap and water in the kitchen sink. My gf loves it when I do that. A noodle strainer works great for little parts. Just make sure to dry the heck out of everything or you will get surface rust. When I tore my t-case apart I just printed direction for  installing 4.7 gears and it went quite smoothly :thumbs:
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
dirtclod01
well that mite be better than my way. a gas bath
dirtclod01
well thanks for the help but the case is toast. get a used one tomarow
dirtclod01
you guys use silicone between the t case and tranny? i got some gray permatex
Sparkplug
why is the case toast? and use the gray silicone, works best IMO
swapped89
i used paper gaskets and they kinda seep. I would use the grey stuff.
yota4x4sc
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
81yotalove
imo= in my opinion and imho= in my honest opinion
81 swb 22re 35's
locked 4x4
dirtclod01
OK guys i have a question. the idler gear Bering and front output berings were in peases not just the little steel balls but also the outside metel rings. and the neddel berings everythings in the bottom of the case.i just got this truck it's a 85 4runner what would cause this? i no the guy let his kid drive it. is this damage normal?
81yotalove
probably ran low on gear oil. i would probably get a full transfer case rebuild and install all new bearings and what not.
81 swb 22re 35's
dirtclod01
i just put in a used one. keepin the old one as a spare
