Author Topic: Rear Toyota discbrake  (Read 21087 times)
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: Rear Toyota discbrake
« Reply #30 on: Dec 29, 2010, 09:27:25 PM »
here is the link on pirate, its davez brakets, not tg's
post # 22
http://www.pirate4x4.com/forum/showthread.php?t=931049
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #31 on: Dec 29, 2010, 09:39:45 PM »
those brackets also use nuts to space the bracket out from the axle backing plate flange.   I still feel this is a bad idea.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #32 on: Dec 29, 2010, 09:43:37 PM »
i would rather have a nut in there, than a 1/4" plate spacer
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #33 on: Dec 29, 2010, 09:45:03 PM »
can u explain why you feel a nut as a spacer is a bad idea? Just curious.
« Reply #34 on: Jan 01, 2011, 08:16:10 AM »
well, look at the stock front brakes.  they are held on by a 14mm bolt(17mm head) into a caliper mount almost 3/4 inch thick.  Toyota did it that way because under high traction, with big tires, a loaded rig, and panic stomping of the brake pedal that little 10mm bolt with the nut spacing it out away from the mount will shear off like a donut at a cop convention.
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #35 on: Jan 01, 2011, 09:04:23 AM »
I agree, no matter how the caliper is clamped down, the bolt is still being used in shear.  You could tighten it down against anything, when you hit the brakes, the bolts gets a shear load.  The only way to get more out of the bolt, is if the shear load was entirely on the shoulder instead of the threads.   :twocents:
I like the caliper mounts.  :thumbs:
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #36 on: Jan 01, 2011, 09:45:30 AM »
but do u see how daves and mine use 3 bolts and the other uses 2 bolts, i still feel safer with 3 bolts spaced out by the nut.
and i did plenty of tests with stomping on the brakes on 37" mtrs and locking them up, never had a problem.
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #37 on: Jan 01, 2011, 10:07:15 AM »
3 is always better than 2  :ladys-man:
81_yota
  • Turtle Points: -41
  • Male Posts: 299
  • Member since Apr '10
  • Parcore !
« Reply #38 on: Jan 01, 2011, 02:54:05 PM »
i would also have to agree 3 is better then 2 but still idk about the nut as spacer but at same time heckits only a spacer if worried about bolts sheering use grade 8 bolt fear gone  ;)
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
  • Member since Dec '10
« Reply #39 on: Jan 19, 2011, 08:24:33 PM »
This is sweet, i have some ifs calipers sitting around and for $50 i can do rear disks.  That beats the $300 to $400 kits everyone sells.
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
« Reply #40 on: Jan 24, 2011, 07:54:02 AM »
here is a place i picked up the brackets i'm using http://www.ruffstuffspecialties.com/catalog/index.php?cPath=9&sort=2a&page=2 they got a few different ones to choose from
so i looked up these brackets and really like them.  it states that you need to use '87-95 IFS calipers and '95.5-'03 Tacoma rotors.  I read on another fourm that they used 85 rotors and calipers, however they used a different bracket.  I like the ruff stuff brackets because they don't use a spacer and are bent, but i would rather use '85 rotors and calipers because i already have them and it would match the front.  What did you use, and is there a differnce between the 85 & 86 calipers to the newer 87 - 95?  Will 85 rotors work in place of the 95.5-03 rotors?
« Reply #41 on: Jan 24, 2011, 09:13:08 AM »
85 rotors are solid, 86 rotors are vented
Techtafab
  • Turtle Points: 48
  • Male Posts: 119
  • Member since Nov '04
« Reply #42 on: Feb 03, 2011, 04:46:01 AM »
wow lets slam the other guy on the forum board !
all pm's and emails have been replyed to thanks guys
GEARED DOWN CRAWLERS
Techtafab
  • Turtle Points: 48
  • Male Posts: 119
« Reply #43 on: Feb 03, 2011, 05:01:36 AM »
got in to toyota crawlers in 2003
been making parts for the guys around here from then and still doing it !
and i have never sold and parts on ebay for crawlers
i'm the little guy that makes parts and buys parts
could not tell you how many marlin doubler boxes i have put together
there is a lot of room out there and i do not feel i should talk down on a guy trying to sell
his stuff for pennys on the dollar. thats all i have been hearing (his stuff is double the cost of mine)
OK !!!! sell yours for what you what to !
i will not get into a price war with anyone !
i have a ton of R&D in my stuff and they are not a cooky cutter part
lets see how long it takes for this post to get deleted !!!
I'M NOT SELLING ANYTHING WITH THIS POST !!!!!!!!!
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #44 on: Feb 03, 2011, 02:39:50 PM »
Why do u keep insisting that I sell brackets on eBay
I don't even have an eBay account
As for being cookie cutter parts, I love cookies
Especially chocolate chip
« Reply #45 on: Feb 03, 2011, 08:18:56 PM »
I dont see a need for it to be removed :dunno:
possume22
  • Member since Apr '09
« Reply #46 on: Feb 04, 2011, 05:54:09 AM »
i run into a problem running solid rotors in back if you get any play in your bearing or just wheel hard it will ruin you caliper and pads fast where they are solid mounted so i used the same brackets and used chevy rotors and calipers from a s10 and havent touched them in two years
Techtafab
  • Turtle Points: 48
  • Male Posts: 119
« Reply #47 on: Feb 04, 2011, 09:42:02 AM »
thats how the front is done from toyota so thats wrong ?
but thats cool this might not be for you !!
possume22
« Reply #48 on: Feb 04, 2011, 01:29:08 PM »
nope it works in front you can adjust the wheel bearing load so there isnt any play like i said i had problems with that setup in the rear when wheeling hard with 42s i dont think they would be any trouble with them on a street trail truck
Techtafab
  • Turtle Points: 48
  • Male Posts: 119
« Reply #49 on: Feb 07, 2011, 04:42:53 AM »
humm guess i need to learn how to wheel hard with big tyers
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #50 on: Feb 07, 2011, 08:31:58 PM »
Not always, in a shear situation a grade 8 bolt will snap faster then a grade 5. Grade 8 is harder and has more of a tendency to break, where a grade 5 is softer and more elastic, so it has more give to it.
OOPS
  • Male Posts: 2,561
« Reply #51 on: Feb 07, 2011, 08:40:35 PM »
That is the play in the bearing cup, when the axle is bolted in the is a small gap between the bearing and the housing end. You need to figure out what the gap is and fill it with a shim behind the bearing in the cup. My rear discs work fine on road, offroad with all the twisting it pushes the pads apart and I have to pump the brakes.
possume22
« Reply #52 on: Feb 07, 2011, 09:15:08 PM »
               it looks like you wheel hard nice buggy i never thought about the play coming from the bearing cup but will look into that.never really understood how with new bearings and hard wheeling my rotors would eat into my calipers so thats why i went to the chevy setup
           oops are you running plastic or metal brake lines
OOPS
  • Male Posts: 2,561
« Reply #53 on: Feb 07, 2011, 09:55:55 PM »
Metal except in the front from the frame to the caliper and in the rear from the frame to the axle I have S.S. flex.
possume22
« Reply #54 on: Feb 08, 2011, 09:45:43 AM »
ok thanks i couldnt tell from the pic
Last post Mar 22, 2003, 04:19:34 PM
by chris672
Last post Mar 18, 2005, 08:18:59 AM
by wrenchtech
Last post Sep 03, 2005, 10:47:23 PM
by 83ROCKR
Last post Apr 20, 2007, 09:08:49 PM
by Rocksurfer
Last post Jun 16, 2008, 04:21:21 PM
by kiyul4130
