Author Topic: Rear Locker delema  (Read 7618 times)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
Re: Rear Locker delema
« Reply #30 on: Nov 11, 2010, 09:54:20 PM »
we install a lot of  the Detroit trutrac in factory vehicles.... they are a "soft" style locker and they hold up well.... no clanking, and minimal spin to lock ratio...
http://www.eaton.com/EatonCom/ProductsServices/PerformanceProducts/Products/Differentials/DetroitTruetrac/
Those are some huge welds!
Tillamook, OR
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #31 on: Nov 11, 2010, 11:12:23 PM »
They are an LSD not a locker. If you do not know how to drive them you might as well be open. I ran one for three years when I was still IFS, learned how to drive it on the trail and it was all right, not great just alright.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #32 on: Nov 12, 2010, 08:17:41 AM »
What is a spin to lock ratio?
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #33 on: Nov 12, 2010, 08:20:34 AM »
That Harrop/Eaton ELocker locker is compatible to "Toyota "Hilux" Front with live front axle assembly (up to 2005)".  :o I want a 2000 Hilux with a front solid axle  8)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #34 on: Nov 12, 2010, 12:16:22 PM »
when i said spin to lock i was refering to the amount one tire would spin before the diff locked in... yes the tru trac is a LSD but it is clutchless and in the trucks i have driven there was almost no differance between that and the full detroit in my friends chevy truck...
FWIW we installed one not to long ago in a 2010 f150 for a customer and i went out with another customer to show them the differance, i drove in 2wd across a pretty decent ditch and had no problems, stoped in ditch, throttled out....
Just got back from a test drive in our new f150 raptor with electronic rear locker, same ditch, same scenerio, felt the same both times..
Tillamook, OR
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
« Reply #35 on: Nov 12, 2010, 12:49:52 PM »
when one tire picks up in the air, you will know the difference.  a limited slip is useless when the tire lifts.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #36 on: Nov 12, 2010, 04:56:41 PM »
Detroit V6 carrier.
You'll never take me alive
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
« Reply #37 on: Nov 12, 2010, 10:05:18 PM »
i have one of these in my front. Open rear. I think it works pretty good and i like how i never have to worry about it. Plus i can turn whenever i want.  I plan on spooling the rear.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #38 on: Nov 13, 2010, 08:27:15 AM »
So and ARB off their site is around $1000 :yikes: Why is everything so pricey if you want it done correctly.
« Reply #39 on: Nov 13, 2010, 10:49:39 AM »
it just scares the hell out of me that youdont know the difference between a detroit and a truetrac and think they are the same as a elocker :shake:
they are no where near the same.  I'm going to assume you are a salesmen because a technician would know the difference.
So right now I have a 4cl Detroit in the rear on 37's and I DD the truck. I hate it. The Detroit has about a 1/4 turn of slop and every shift, accel/deaccel and crawl it kicks and bugs the heck out of me. I want to replace it.
My questions are:
Does an E-locker have a lot of slop?
Will a 4cl Aussie hold up?
 :beerchug:
your detroit probably isnt your problem it sounds like you have an extreme amount of backlash which would cause the condition you explained.
or the springs in it could be broken
« Reply #40 on: Nov 13, 2010, 11:04:07 AM »
here is the older version that you might have. it shows the "cross" without the case
toyyota
  • Member since Apr '08
« Reply #41 on: Nov 14, 2010, 07:48:50 PM »
So, You have created quite a bit of chatter. Bottom line seems to be, Selectable is the way to go for trail or street if your in it for the long haul. I bet Marlin does not have welded diffs. Step up...do it once...see you on the trail, its more fun to drive for me.
OOPS
  • Male Posts: 2,561
« Reply #42 on: Nov 15, 2010, 08:13:04 PM »
I disagree with this, yes I run ARB's F & R because my rig used to be a DD, my daughter used to drive it to high school. But now it is a trail rig period and a trailer queen to boot. If I were building a trail rig only I would go with an ARB up front and a spool in the rear. I might as well have a spool now because as soon as my rig is off the trailer, the rear is locked in. Why waste the money on the rear.
OOPS
  • Male Posts: 2,561
« Reply #43 on: Nov 15, 2010, 08:14:27 PM »
If you go to Europe you can get one up to 95.
Last post Feb 19, 2006, 12:37:16 PM
by kyle_22r
Last post Apr 13, 2006, 11:27:47 AM
by 89 toy
Last post Jan 14, 2007, 04:32:22 PM
by got cope?
Last post Jun 11, 2007, 08:58:18 PM
by Rockcrawlintoy
Last post Jan 24, 2010, 12:02:50 PM
by yotaneck13
