What year did the toyota V6 engines stop having problems
Started by ae racer, November 04, 2010, 02:56:23 PM
ae racer
Ok guys, im wondering when the v6 trucks stopped having the head gasket problems and such. Im looking at getting a new wheeler and wanted a v6 w/o the problems the early ones had.
CrawlerBrennan
after the recall they were fine. i dd a 3.0 and take it to 5XXX all day
Lets go camping
CrawlerBrennan
What im saying is all 3.0s are fine just make sure they have had the recall done to it.
After that as long as to take care of it, it will take care of you..
Lets go camping
ae racer
the reason im needing this info is i found a 93 5 speed v6 3.0 that might run (havnt heard back from the seller) for  cheap and was wondering if it would be a good base or if i might have problems with it.
CrawlerBrennan
i would be vary careful to buy with out knowing a lot about why that 3.0 is so taken apart/ misssing covers ect.
Lets go camping
ae racer
well its sold anyway...lol, just got a message from the seller..lol
but back to the topic at hand, any v6 should be fine if its been through the recall...so what year did they become "fine" from the factory?
CrawlerBrennan
couldn't tell ya man sorry i have a 90 and my Dad has a 92 that both got the recall so after 92 at least.
Lets go camping
superyota
i don't think 88 or 89 had the recall.  not 100% sure though.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Snowtoy
Toyota v6's including the first few yrs of 3.4 had HG issues up until the late '90's.  From what I could get out of the Service manager at my local dealer was that HG issue was do to Toyota designing the engines w/asbestos gaskets, then being forced to use non-asbestos gaskets by the Fed.s, and then failing to come up with correct torque values for the non-asbestos gaskets.  This was also an issue with the 7m series of engines.  Repeat HG issues were either from poor/ignorant repair work, either not inspecting the head or re-using the torque-to-yield head bolts, and not following the exact procedure Toyota set out in '98.  If you did a quality rebuild and went ahead and used new TTY bolts, the HG issue was fixed, of course you still have the issue w/burnt exhaust valves, and leaky valve covers, both of which are also easily fixed.  I am not sure which helps more on the burnt valve issue, Headers(negating the poor exhaust design), or setting(shimming) the exhaust valves one # lower than is being measured, I did both to mine in '04 and haven't had anymore issues w/burnt exhaust valves, while I had 2 w/in 5yrs before.
If you are looking to buy a good condition running 3.0 rig for going market value, make sure hat the HG recall was done through Toyota, and not a shop that may have cut corners.  All you have to do is call a Toyota Service department and ask if the HG recall was done to the VIN number you are looking at buying, if yes, then you should be fine, depending on what the rest of the service history of the vehicle has been like.  Otherwise look for one w/a bad HG, or burnt valves, shouldn't cost you more than $1500 for one in "Good" condition, and repair the engine yourself.
yota4x4sc
get a 95.5 3.4 motored car or truck... i hate the 3.0.. but if u get a 3.slo get a 92 and up.. better design..improved parts on them
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
bigarms23
TacoRunner
www.4WHEELUNDERGROUND.com
[email protected]
