How to make engine mounts for Drive train lift
Started by MidgetMike, December 30, 2004, 09:58:13 PM
MidgetMike
Who's done a drivetrain lift and how did you make the motor mounts the back is easy I am wondering how to do the motor mounts. Should I cut them off and move them up or make a relocator plate for the engine block portion of the mount Help :flamer:  :twocents:  :turtle:
Leave them where they are.  Just loosen the nut on the engine side of the mount raise the t-case and tighten them back down.  Thats all I had to do and Im sure I raised the cases farther than most will.
mr4x42u
You can go flatbelly with out moving the engine mounts,,jsut used a few links of chain and weld it to the frame and to the metal plate that goes over the mount,,this will keep them for pulling apart,,3 links of large chain for each side worked for me..You will need to cut out the fan shroud a little for the fan..
I lowered the radiator about 2" but everything else worked fine.
MidgetMike
Sweet I never thought of lowering the radiator, I'll give that a try and just lift the tranny. :turtle:
If you really want to move the mounts you could cut them off and put a piece of 2x2 inbetween them and the frame.  But keeping them there wouldn't hurt either.
Mountain Yoat
Is there a reason the engine is supposed to be mounted at a 4 degree angled towards the rear  :headscratch:
camo89
ya there is on  a street truck but think how often is your wheeler on level ground
mopar parts
MidgetMike
Quote from: Mountain Yoat on January 03, 2005, 11:26:25 AM
Is there a reason the engine is supposed to be mounted at a 4 degree angled towards the rearĀ  :headscratch:
I noticed that today while making my t-case cross member template, not the # of degree's but the angle of the tranny and engine. I thought a 2" body lift would give more room to lift the t case than it does. I geus I will probably still have to cut the floor board a bit  :flamer:
