Author Topic: hydro assist  (Read 5670 times)
E YOTA
  • Male Posts: 690
  • Member since Jan '04
hydro assist
« on: Oct 27, 2010, 11:39:24 PM »
is hydro and ram assist steering the same thing or different....please explain
built lastnight, crawl today...
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
Re: hydro assist
« Reply #1 on: Oct 28, 2010, 01:16:12 AM »
hydro assist and ram assist are the same thing, you use a hydraulic ram.... (uses a cylinder plumed from the steering box -> cylinder) still has mechanical linkage steering wheel to steering box to wheels
now full hydro steering is not...(uses a hydro pump -> steering valve -> hydraulic cylinder) has no mechanical linkage from the steering wheel to the wheels
Those are some huge welds!
Tillamook, OR
E YOTA [OP]
  • Male Posts: 690
Re: hydro assist
« Reply #2 on: Oct 28, 2010, 08:31:08 AM »
thats wat i needed to kno but wat is beter...will the ram assist do the job cuz its a whole lot cheaper...
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: hydro assist
« Reply #3 on: Oct 28, 2010, 09:30:25 AM »
Depends on your setup. Full hydro steer is a little crazy so most will run hydro assist. The assist should be all you will need. Plus, if the hydro assist craps out on you, you still have a mechanical link so you don't completely loose all steering  :twocents:
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: hydro assist
« Reply #4 on: Oct 28, 2010, 09:33:57 AM »
what tire size? do you plan on EVER having on the road? i'de say for anything over a 39, full hydro would be nice.  but if its ever going to see the road, forget about full hydro, its too dangerous.  if your motor dies for whatever reason, or you lose a belt, there goes you steering with it.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
Re: hydro assist
« Reply #5 on: Oct 28, 2010, 10:57:11 PM »
yea i never even thought bout the engine driven pump on full hydro lol.... talk bout Armstrong steering.... that would suck...
for a yota axle the 8" stroke is more than enough... and most would run something like this https://www.surpluscenter.com/item.asp?item=9-4410-08&catname=hydraulic
but if you would need more power you could up the piston/rod size... but when you go bigger you need a better pump also...
Tillamook, OR
TractorDriver
  • Male Posts: 20
  • Member since Sep '10
Re: hydro assist
« Reply #6 on: Oct 29, 2010, 03:06:02 PM »
I dont know where people get that you loose all steering if the motor is off or the belt breaks!!! All steering valves that you buy for a offroad vehicle or any vehicle will still operate. The only difference is that you become the pump yes very hard to steer but have you ever driven a 4x4 with a locker in the front without power steering same thing! The only time you loose steering is if you loose fluid, if one of the steering hoses break it wont turn that way but it will still turn the other direction... Hydro assist is perfectly fine as long as you dont have a long travel suspension.
Rock Tractor Racing
Gasss Ittt!!!!
Climbintathatop!
Special Thanks to: MarlinCrawler, Inc.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: hydro assist
« Reply #7 on: Oct 29, 2010, 03:44:49 PM »
Long travel as in Super long travel :) If your leaf sprung, you will be okay.
E YOTA [OP]
  • Male Posts: 690
Re: hydro assist
« Reply #8 on: Oct 29, 2010, 06:23:24 PM »
cool.. im runnin 37/14.5 and it gets a little hard to turn when im locked....wheres the best deal i can kit a complete kit for hydro assist...
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
Re: hydro assist
« Reply #9 on: Oct 29, 2010, 07:44:41 PM »
Not entirely true... with most valves you will still have steering in those cases
Do you need a Hammer?
IronClad
  • Male Posts: 2,284
Re: hydro assist
« Reply #10 on: Oct 29, 2010, 07:50:49 PM »
Im sorry how does how much suspension travel you have  deal with if you can run hydro assist or not ?
i have hydro assist on that.. 40" boggers 3 link etc and that is not full travel.. so i dont really follow
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
Re: hydro assist
« Reply #11 on: Oct 30, 2010, 10:27:21 AM »
Only on an IFS truck it will matter.
IronClad
  • Male Posts: 2,284
Re: hydro assist
« Reply #12 on: Oct 30, 2010, 02:20:41 PM »
er... what? how?
potter85
  • Male Posts: 257
  • Member since May '09
  • complete disregard for sheet metal.....
Re: hydro assist
« Reply #13 on: Oct 30, 2010, 02:58:12 PM »
long travel.... haha uhh there is no problem with that. unless you worried about the lines. but you can get any length line you want
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: hydro assist
« Reply #14 on: Oct 30, 2010, 03:42:04 PM »
True, I still turn with motor off, no worse than without assist.  :)
TractorDriver
  • Male Posts: 20
Re: hydro assist
« Reply #15 on: Nov 02, 2010, 03:23:55 PM »
 :smack: @ Ironclad What I was saying is if you have long travel suspension (3link or 4link anything more than a leaf spring) it is better to run full hydrolic since when you have long travel suspension when the tire opposite the steering gear box is at full droop or at full stuff it limits how much your tires actually turn!!!  If you havent noticed that when your passenger tire is at full droop it wont turn right as much and when its at full stuff it wont turn as far left ??? If you have FULL Hydrolic the steering is attached to the axle and always turns an equal amount!!!  :therethere:
« Last Edit: Nov 02, 2010, 03:54:09 PM by TractorDriver »
Rock Tractor Racing
Gasss Ittt!!!!
Climbintathatop!
IronClad
  • Male Posts: 2,284
Re: hydro assist
« Reply #16 on: Nov 02, 2010, 09:40:54 PM »
Sounds like someone didnt build their suspension correctly.
im 3 link + panhard and have 0 steering limitations other than when i get into my bumper hard. full stop to stop on the knuckles.. still dont see how you figure that
potter85
  • Male Posts: 257
Re: hydro assist
« Reply #17 on: Nov 13, 2010, 08:57:35 AM »
hahahahah thats hilarous i raced a nova in hs that was a circle track car and it only turned left as well :)
3rz in the making
looking for 38s
potter85
  • Male Posts: 257
Re: hydro assist
« Reply #18 on: Nov 13, 2010, 09:02:17 AM »
if you run full hydro on the road you cannot "feel" the road so around 50 plus you constantly start overcorrecting and will just lose control.
the hydro assist does exactly what the title says. it assists tho load in turning the wheels but being that you still have a positive mechanical connection you can in a sense still "feel" the road
3rz in the making
looking for 38s
k-nutty
Re: hydro assist
« Reply #19 on: Feb 07, 2011, 02:18:40 AM »
how much does a basic hydro setup run ya?
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: hydro assist
« Reply #20 on: Feb 07, 2011, 09:12:58 AM »
I did mine for 140 bucks, including tap what not. Hydro assist takes away a bunch of feeling on the road also. It lags a tad, and can get sketchy at times. But, like most things we do to our trucks, theres a tradeoff for off road performance vs on road performance. I will never again run a rig on 35 or bigger tires without hydro assist, Ive been ruined.
k-nutty
Re: hydro assist
« Reply #21 on: Feb 07, 2011, 11:27:59 AM »
oh thats not to bad at all. and from what it sounds like the tradeoff is well worth it. do you recommend any certain brand ram or any other parts.
yotatough
  • Turtle Points: 16
k-nutty
Re: hydro assist
« Reply #23 on: Feb 07, 2011, 04:56:33 PM »
thanks for the link.
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
Re: hydro assist
« Reply #24 on: Feb 10, 2011, 09:07:13 AM »
my buddy has a bronco with full hydro steering and its so easy to turn the wheel im in love ...just wish i could afford it for my toy :down:
k-nutty
Re: hydro assist
« Reply #25 on: Feb 10, 2011, 10:58:00 PM »
yeah i bet. haha
Rockin4Runner
  • Turtle Points: -10
  • Male Posts: 100
  • Member since Jan '11
Re: hydro assist
« Reply #26 on: Apr 11, 2011, 04:22:36 PM »
I'm just curious, how do hydro assist. rams hold up to going somewhat fast across the desert (40mph). I'm not saying to drive the rig like a trophy truck threw 3' deep whoops at a 130MPH but you now, sliding at ass end around well going around turns and going across bumps that are roughly 8-10" tall at 40MPH  :driving:. Will it bend the shaft or blow the seals out on the ram?
Thanks
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Re: hydro assist
« Reply #27 on: Apr 20, 2011, 05:17:32 PM »
X2  and my truck is a dd. I did add a after market ps pump to my setup, it's so nice to turn 37x14.5x15 with finger tips.
« Last Edit: Apr 22, 2011, 02:17:55 AM by YosHaleng »
Last post Mar 05, 2006, 04:37:42 AM
by POWERSTROKEN
Last post Jul 24, 2010, 10:14:40 AM
by megolfer
Last post Sep 15, 2007, 09:25:38 AM
by subliminaltrips
Last post Oct 13, 2010, 11:53:27 AM
by -Jake-
Last post Nov 05, 2010, 07:49:33 PM
by THK Matt
