L50 shifter stuck
Started by superyota, October 25, 2010, 11:12:30 AM
superyota
I pulled the cover with the shift forks off of my L50 to check the gears and syncros before i installed it.  now, i put it back on, and as far as i can tell, everything is lined up, shift forks in place.  but when its all back together, the shifter doesn't move.  any ideas?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
you have it in 2 gears remove the cover again and make sure everything is in neutral
superyota
sorry for the stupid question, but if i spin the input shaft, and i can hold the output to where its not spinning, thats neutral, right?
ABD Motorsports
#4475
KK6QDW
superyota
also, reverse gear was showing a little(minimal) wear on the edge.  should i change out the gear, or leave it alone?
ABD Motorsports
#4475
KK6QDW
Quote from: superyota on October 28, 2010, 10:20:02 AM
right
Quote from: superyota on October 28, 2010, 10:21:13 AM
leave it alone
superyota
thanks for the info.  i'll give it a shot.
ABD Motorsports
#4475
KK6QDW
