Author Topic: Knock Problem!  (Read 1257 times)
bamajojo9
  • Member since Apr '10
Knock Problem!
« on: Oct 19, 2010, 09:41:05 PM »
so i just bought an 87 yota that has a 22r with only about 40 or 50,000 miles on the motor. but im 16 and dumb and out this truck knowing about the supposive loose valve in the motor that makes the slight knock sometimes. at least thats what my buddy told me it was.. its not really bad or anything just wondering if its something i should be worried alot about and if that is more than likely what it really is.?? it only really occures whenever the rpms go high and i need to shift gears?..
bamajojo9 [OP]
Re: Knock Problem!
« Reply #1 on: Oct 19, 2010, 09:45:30 PM »
so im 16 and dumb and just bout an 87 yota with a 22r with about 40 or 50,000 on the motor knowing it had a slight knock that my friend told me was a loose valve.. it only really occurs whenever the rpms get high and i need to switch gears.. i just wanted to know if thats what it sunds like to yall and if its something i really need to be conserned about?? and i have a zuki with a rod knockin and the yota is NOTHING like it. just any replys i would really appreciate!
bamajojo9 [OP]
Re: Knock Problem!
« Reply #2 on: Oct 19, 2010, 09:46:14 PM »
wow that^ made me look stupid
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Knock Problem!
« Reply #3 on: Oct 21, 2010, 12:04:39 PM »
:haha:  yea  a little
if its doing it only at 3500-4000 when your not really pulling anymore but before you let off to shift then its more than likely wristpin slap.  not a good thing but not as bad as a rod knocking.
what oil are you running?  you need to change the oil VERY often if its black change it.  i had a celica years ago when i got it the oil was black and gooey.  i changed the oil ran it for ten minutes with new oil and it was black again. i ran it a couple days then used some "Rislone" to cut the sludge then changed the oil again.   it lasted about a week before it was nasty black again.
if a motor is run till sludge builds up bad then that sludge has to be cleaned out.
when you change the oil you need to go up to 10w40 unless thats whats in there now but i bet its not
Last post Feb 16, 2004, 09:02:47 AM
by brainlessfool
Last post Jul 27, 2007, 03:19:22 PM
by AaronB
Last post Feb 14, 2008, 03:47:46 PM
by Glen1978
Last post Apr 29, 2008, 09:28:24 PM
by JohnHalladay
Rod knock
Last post Dec 13, 2009, 10:41:04 PM
by ftoy07
