79 yota 100% smog legal 4.3 v6 swap/full ***sold***
Started by crawlerbubba, October 16, 2010, 11:09:12 PM
crawlerbubba
79 toy,fuel inj 4.3 chevy v6,700 r4,np 241 t case,almost flat belly,brand new exhaust done right and very clean,flowmaster,high pinion 44 front,high steer,gussets,4.10 gears,8 lug,steel braided brake lines,1 ton chevy master cylinder,new alternater,new fan clutch,new belt tensionerbattery kill switch,brake lines run through spring perch,seperate coolers for atf,and one for power steering pump,jeep box,frame sliders,new battery,rear axle is a 05 aam axle,like a 14 bolt,but has oem disc brakes,steel braided lines,4.10,posi,new ranchos,35 in bfg a/t,90 % tread,48 inches of travel,waggy fr springs,ford rears,long bed bobbed to short bed length,interior cage,ford 60/40 bench,b&m quicksilver shifter,engine swap done by a profesional mechanic out of chico,done right,and he is meticulus to detail,reff aproved,has carb sticker,and has tons of power for bigger tires.everything works right.please call 530-526-7708cel.530-474-5776,home.,.located in red bluff area,way nor cal,i will smog when sold,asking $4500.00,obo need a truck,or...???...looking for a 450 or bigger quads..also interested in built samies
GOT ROCKS?
Sparkplug
I didnt happen to meet u at the junkyard on walnut did I? Maybe a 6 months or so ago, talked to u a lil bit about ur truck, but i thot u sed it had a ford motor if it was u, Wondering cause truck looks familiar. Free bump neway
crawlerbubba
GOT ROCKS?
crawlerbubba
GOT ROCKS?
freeriders98
Would you be interested in a trade for a 2001 Suzuki Bandit 600?, tried to send you a PM but I'm to new!!! :greengrin: :greengrin:
crawlerbubba
new pics
GOT ROCKS?
crawlerbubba
more
GOT ROCKS?
crawlerbubba
GOT ROCKS?
snowcat
snowcat
motormouth559
Interested in a DD I got a 1988 yota reg cab short bed clean fresh lift and gears smog and title in hand ? Im not looking to sell or trade but id trade for your rig !
crawlerbubba
GOT ROCKS?
motormouth559
why cuz i want it  :therethere:  .. didnt know if you want a clean 2nd gen  . no prob GLWS  :beerchug:
crawlerbubba
ide trade for a built 2nd gen,but not a stocker unless you got cash on top.....
GOT ROCKS?
