header gasket
Started by Skinny_Pedal, December 28, 2004, 07:23:47 PM
Skinny_Pedal
which gasket should i get for my header?
Im an OG
brainlessfool
can"t help ya there. mine don't use any.  :dunno:
SWAMPER
Get metal ones....I heard that either way you may have to replace them offten :shakehead:
Im using the origional stock one from the 94 and it doesnt leak a bit.
reklund5
Another vote for the factory Toyota gasket.  My TRD header doesn't leak at all!!
Ryan
FATB0Y
Uncle Jesse
Toyota factory gasket.  Has fire rings built in.  Has heat shield built in.  Even if the header is supposed to have another gasket, you can normally massage the heat shield to get the toyota gasket to fit.  I ran one behind my "wrong side of the flange welded" thorley, worked fine.
