Supra Truck question
Started by u887266, September 27, 2010, 07:16:23 PM
u887266
I am currently rebuilding my 7m Supra motor to put in my 85 truck.  My question is, do any of you guys have any recommendations on what kind of cams would be good to put in this engine to get the most low end power as possable?  Or do I just need to keep the stock cams in it?  Any advice would be great.
1985 22r with lots of possibilities.
Snowtoy
Not a lot of upgrades for the 7mge, and wringing more power out f it is about it is about as easy and inexpensive as the 3.0.  Most in the Supra community ditch it for a 7mgte, 1j or 2j, due to the high costs and low HP gains.
Some Supra vendors worth checking out
http://www.titanmotorsports.com/
http://www.driftmotion.com/
and several listed here about 2/3's down
http://www.supramania.com/forums/forum.php
A simple power build, i.e. bore the block, port match the intake/exhaust to head, possibly larger valve would gain you some, but might not be worth the $$ for HP gains.  I would do a little research on Supraforums or Supramania, and see what some of the 7mge owners have done and what gains they have gotten.
laskt9
question, why two threads instead of just one?
toyota sr5
use the stock one there are none for this old engine
SCyotacrawler420
actually there are alot if you have a supra motor in your truck, brian crower makes just about everything for these motors, i have crower cams in my 7mgte. they make all kinds of different lift cams for more low end or high end power
SCyotacrawler420
OH YA! dont port the head! you lose alot of torque with these motors!
yota4x4sc
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
4RunnerChevy
dont do anything, the 7 is a good motor,  who cares about 4500 + rpm horsepower.
