chevy axled yota
Started by 19801981, December 27, 2004, 08:28:19 AM
19801981
 :hammerhead:  :love: could some one tell me how to do a full axle swap the right way and make it work what do i need and how
planning on running 44's or monster truck tires??
camo89
well you build a front hanger use chevy springs and use stocl type chevy shackles in the toyots locaton it worked for me aney wahy
mopar parts
19801981
sounds good howd u fab your hanger and what about front rear shackle,, and the rear axle the same? :wave:  :bowdown:
Makohon
rear axle you dont have to do anything but move the spring perches on the axle closer together and rotate the pinion up a lil but... but if you go with longer springs just cut off the old spring hangersand weld some new ones farther apart.... as far as the front goes just make the same kind of hanger marlin sells but just make it wider to work with the chevy axles!! and then for the shackle hanger for the front do this...................................
Makohon
never mind... my comp at work wont let me do pics!!! so just go to http://isuzu4x.com/modules.php?set_albumName=album03&op=modload&name=gallery&file=index&include=view_album.php
its an isuzu but its the same damn process with doing chevy axles ect.....
greengo
heres a link to a friend who went 14 ff and dana 60 on a 2nd gen ext cab. hope it helps...
http://www.arcticoffroad.com/modules.php?name=Forums&file=viewtopic&t=633
"No Habla Jeep"
You need to decide if you wanna run your toyota u joint's or if you wanna run chevy u joints.  You can buy flanges from High Angle Driveline so you can run the stock toyota drivelines with the full sizes.  I think they have both dana 44 and dana 60 flanges.  then you need to figuer out what kind of steering you want.  You want highsteer crossover or highsteer full hydrolic?
19801981
wow!!!!!! now thats customer support, thanks it all sounds great and ill have to get the axles n go to the drawing board maybe it will happen by april
19801981
u knows how much it will cost .. with out buying axles, i got welder torch cutter and a good tree with a come a long.... :sly:  :twocents:
