popping out of 3rd.
Started by brainlessfool, December 26, 2004, 09:50:23 PM
brainlessfool
got a bud that is telling me his 92 R150F is popping out of 3rd if he does not hold it in while letting the clutch out? bearings?  any  :idea:   post up! thanks...the fool  :beerchug:
shifter seat maybe?
FATB0Y
Mine did that when I got it but it went away :confused:
:psss: I think it your sinkranizers (can't spell worth a fu@k) I had that on an 89 and that is what it was. :yupyup:
how many miles on it brainless,   if its hi, i would say input bearing is toast,  usually feel it in third 1st,  least ways i did in mine
brainlessfool
Quote from: brainlessfool on December 27, 2004, 12:52:18 PM
115K, just broken in! :dunno:
i bet its the shifter seat,   leat i would check that first
Marlin
Begin by replacing the seat and socket.
I sell a heavy duty replacement that is much better than stock.
If it still pops out of gear, I would supect a worn mainshaft bearing retainer.
As a result, the mainshaft is moving, and walking the shift collar out of contact with the 3rd gear.
I sell a heavy duty plate to fit that also. It is on my trans page.
Check for supended aluminun in the oil, it could be a worn fork. However, this is not a common failure.
Of course, I would advise a rebuilt trans, but as long as you do not have worn out bearings, the trans could be "patched up".
brainlessfool
ZaCk'S 83
if u have a body lift in the truck then that could also create a problem
brainlessfool
BLACKDOG
I have that problem too, in 1st and 3rd.  otherwise, the tranny works fine, no problems at all.  I also have a 3"body lift, so could that be the problem??  The clutch was just replaced last april(?) and I replaced the shifter socket at the same time.
              -Ronald Reagan
FATB0Y
 :yesnod: BD to find out if the lift is the problem all you have to do is take the boot off of the shifter put it in 1st or 3rd and see if the shifter is hitting the edge of the hole in the floor if it is you can grind or cut the hole out where it is hitting...trust me I had to do it to my 89 yoda when I installed a 3" body lift. :yupyup:
BLACKDOG
it was a pain in the :moon: to take that boot off
              -Ronald Reagan
FATB0Y
Jumping out of 1st or 3rd is also a pain in the :moon:
BLACKDOG
If its under power, it doesnt do it.  It is only when I pull up to a stop and push in the clutch, then it will drop out, or if I dont hold it while  I give it gas and let out the clutch.  I can cruise without holding them all day, as long as the truck is rolling under power, and not coasting.  I've gotten to the point where I hold it in gear subconsciously :dunno:  :driving:
              -Ronald Reagan
FATB0Y
If it is hitting the body it will do that...when it is under a load it will hold itself in gear. :psss:  when you let off the gas in 3rd to slow down does it also jump out ??? have you pulled the boot off and looked ???
