Author Topic: shackles  (Read 3434 times)
foxtrot89
  • Male Posts: 68
  • Member since Jul '10
shackles
« on: Sep 11, 2010, 08:25:16 PM »
Currently on my 1989 Toyota 4runner, there are some ghetto rigged shackles. There is 8 1/2 inches between the middle of each hole (top bolt to bottom bolt). I am looking to purchase some new shackles, espically since they are on sale right now. since marlin only makes 6 inch shackles (hole to hole, or end to end?) what else could I do to make up the other 2 1/2 inches  :headscratch:
1989 Toyota 4runner - 22RE 265xxx miles, 35"tires, 5.29 gears, aussie locker in the rear, marlin 1600 lb clutch, still starts and runs like a charm
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
Re: shackles
« Reply #1 on: Sep 11, 2010, 09:43:14 PM »
do you really need the extra 1.25 inches of lift your going to loose?..    maybe add an extra leaf, or some type of zero rate piece of steel (sorta like a lift block just smaller).......
guess this would work for the front and the rear.....since i dont know which end your talkn bout
Those are some huge welds!
Tillamook, OR
foxtrot89 [OP]
  • Male Posts: 68
Re: shackles
« Reply #2 on: Sep 11, 2010, 09:47:38 PM »
sorry, rear. so when they say 6 inch shackles, is that 6 inches longer than stock or 6 inches al together? where do you get 1.25?
foxtrot89 [OP]
  • Male Posts: 68
Re: shackles
« Reply #3 on: Sep 11, 2010, 09:49:38 PM »
also, whats the differenct between the 89+ and 88-? and is it a set of two that comes in the kit? i assume lol
just looked at your build thread, those are the same rear shackles that I have currently
« Last Edit: Sep 11, 2010, 10:02:22 PM by foxtrot89 »
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
Re: shackles
« Reply #4 on: Sep 12, 2010, 12:52:02 AM »
i think the 89+ has thicker leafs like 3" as where the earlier are 2 1/2. not sure on this though
6" usually refer to bolt holes center to center...
shackles only lift half the spring so if you have a 6" shackle and you put a 8" set on it would be a 1" difference.. unlike if you throw a 2" block in you would get 2" of lift...
lol... those shackles suck... but they work for me at the time being, and i ALWAYS carry my stockers,  just in case lol
Tillamook, OR
foxtrot89 [OP]
  • Male Posts: 68
Re: shackles
« Reply #5 on: Sep 12, 2010, 03:05:57 AM »
ok cool, that makes sense. those shackles have worked as my rear bumper :)
I have 63" chevy's, so do you know if they will work with those?
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
Re: shackles
« Reply #6 on: Sep 18, 2010, 01:49:58 PM »
This actually depends on your shackle angle, which will change with shackle length.
If you need a custom length shackle, just go to the steel yard and get some 2inx3/8 starp.  Cut it into 4 pieces, than clamp those 4 pieces together and gang dill all the holes all at once.  This makes it much faster, and you know that they are all the same. If you wanna get real fancy, grind the corners round.
Remember that shackles are not a science.  What works for me may not work for him or you or the next guy.  I would say if you don't have the equipment to make your own, order the big ones from Marlin, and find a fat anti wrap leaf, cut it so its just a block and add it to your leaf pack.
PZ
rockin86runner
  • Turtle Points: -18
  • Male Posts: 871
  • Member since Nov '07
Re: shackles
« Reply #7 on: Sep 18, 2010, 02:04:07 PM »
do you have the overload spring on.... i cut mine so its kinda like a small block lift
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
 :usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
Re: shackles
« Reply #8 on: Sep 18, 2010, 03:19:31 PM »
Why not drill new 18mm holes in your existing shackles where you need them and cut the excess off ?
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: shackles
« Reply #9 on: Sep 18, 2010, 11:24:56 PM »
PZ
Just did this today, made shackles for 8 bucks, and still have enough steel to make 2 more sets up to 9 inches long. Bought the steel at Tractor Supply Co
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: shackles
« Reply #10 on: Sep 20, 2010, 07:30:52 AM »
If you're going to make some 8" shackles, I'd suggest some kind of brace in the middle.  I'm running 5.5" shackles and plan on cutting them down to help me lower my rig 1-2" this winter.  Can you lower the front rather than lifting the rear?
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
foxtrot89 [OP]
  • Male Posts: 68
Re: shackles
« Reply #11 on: Oct 12, 2010, 10:21:15 PM »
thanks for the help guys! I got the shackles, and had to machine down the buushings 3mm for the leaf springs, and it lowered it quite a bit. if I left it here, I think i might need to cut if I leave it here :( I don't think I could lower the front, unless I remove some leaves.
Last post Feb 10, 2004, 10:53:24 PM
by WHITE_TRASH
Last post Feb 24, 2004, 10:58:02 PM
by WHITE_TRASH
Last post Jun 24, 2004, 09:04:46 AM
by yotaboy79
Last post Dec 14, 2004, 07:20:51 AM
by billy hill
Last post Feb 22, 2005, 12:59:18 PM
by WHITE_TRASH
