Those are some huge welds!
i think the 89+ has thicker leafs like 3" as where the earlier are 2 1/2. not sure on this though6" usually refer to bolt holes center to center...shackles only lift half the spring so if you have a 6" shackle and you put a 8" set on it would be a 1" difference.. unlike if you throw a 2" block in you would get 2" of lift...lol... those shackles suck... but they work for me at the time being, and i ALWAYS carry my stockers, just in case lol
ok cool, that makes sense. those shackles have worked as my rear bumper I have 63" chevy's, so do you know if they will work with those?
If you need a custom length shackle, just go to the steel yard and get some 2inx3/8 starp. Cut it into 4 pieces, than clamp those 4 pieces together and gang dill all the holes all at once. This makes it much faster, and you know that they are all the same. If you wanna get real fancy, grind the corners roundPZ
Started by Thumper Parts Wanted
Started by Jared General 4WD Discussion
Started by yotasrockontherock « 1 2 3 » Project Research and Build-Ups
Started by Bigbadtoy Engine
