85 4Runner, lifted and locked. Upstate NY $5500
Started by hiltu, September 09, 2010, 07:32:31 AM
hiltu
The truck for sale is a 1985 Toyota 4runner with the original great running 2.4L 22RE with just north of 77,800miles (NO BULL) located in Saratoga Springs, NY. It is the delux (base model), red exterior with a tan/brown interior. The seats are in really great condition, no tears. The driveline is that of an 85 with the cab and shell of an 86, therefore the VIN/registration will be for a 1986 4runner. I have paperwork showing the original owner of the 1986 vehicle purchasing the Ziebart undercoating and to this day, you can still see most of it underneath. The frame is also in excellent conditon. It's very solid and I recently rustoleumed it with several coats. Prior to me purchasing the vehicle the previous owner had replaced these items: oil pan, alternator, ignition module, plugs, wire, cap, rotor, cd player (Pioneer), water pump, and rear brake lines. It does also have a newer battery. There are several small things on the truck that don't work, the cigarette lighter doesn't work and the rear window would go down but not up. One other negative is there is some (minimal) cancer around the edges of the fenders. All gauges work, 4wd hi and lo work, the ARB locker works, headlights, etc. Because of the rear window not being able to roll back up, I chopped the topper in order to seal off the cab and be able to use the tailgate. The topper and truck bed were than lined with Sante Fe Brown grizzly grip bedliner. I had a 400EX fourwheeler fit perfectly in the back with the topper cut the way it is. Also, the reason I went with 5.29 gears is my intentions were to put 35's under it, which will result in a near stock final drive ratio therefore keeping the speedometer correct. The 33's however have a lot of tread left so replacing them is far off. I'm not in dire need to sell this at this time so my price is pretty much firm. Its an extra car insurance payment and takes up room in the driveway, but i still enjoy to drive it 3 or more days a week. I can deliver approximately 200 miles for a small fee from zipcode 12866. Here is a list of most of the modifications done:
MARLIN CRAWLER:
2x pumpkin protectors: $140 NOT INSTALLED
extended brake line kit: $85 FRONT NOT INSTALLED
clutch master cylinder: $59
ARB front diff w/ 5.29s: $1379
ARB compressor: $251
Grizzly rear diff w/5.29s: $1049
front axle rebuild kit: $165
rear axle rebuild kit: $145
TOTAL: $3273
LONGFIELD SUPER AXLES:
30 spline chromoly axles: $630
wiper seals: $30
TOTAL: $660
TRAIL GEAR:
chromoly rear axles: $249
TOTAL: $249
MISC:
Original purchase price: $3000
SR5 gauge cluster w/
oil sending unit: $90 NOT INSTALLED
aftermarket rear bumper: Free NOT INSTALLED
homemade front bumper: Free NOT INSTALLED
3" Rough Country lift kit: came with truck
33" procomp w/1 spare: came with truck
15x10" aluminum wheels: came with truck
new air filter: $20
new rear pads: $30
TOTAL: $3140
GRAND TOTAL: $7322 + cost of fluids and odd ends
*More pictures/info can be obtained by replying to this ad
