Author Topic: Guage Clusters  (Read 1374 times)
tree18is
  • Member since Sep '10
Guage Clusters
« on: Sep 05, 2010, 01:45:31 AM »
 :usa:  Thanks for having me
 After reading the HIGHLY technical posts on this board I hope this doesn't bore you guys.
     I just got a 94 pickup and its the base model, I was wondering if the harness supports the clusters from the higher trim level trucks.
 Im really looking to get the Tach cluster and w/e comes on it.
 Thanks alot
Tree.
tree18is [OP]
Re: Guage Clusters
« Reply #1 on: Sep 05, 2010, 01:46:38 AM »
I now see the forum where this belongs. Can the MODS please move. thanks.
OOPS
  • Online The 2.5K Group
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Guage Clusters
« Reply #2 on: Sep 05, 2010, 05:08:31 PM »
Just going by my 90 I am going to say yes. You also have to change the oil pressure sender from the idiot light to the gauge sender. If you do not do that you will burn the gauge up.
AToyota2NV
  • Male Posts: 8
  • Member since Jul '09
  • Live Free or Die!
Re: Guage Clusters
« Reply #3 on: Sep 09, 2010, 07:39:21 PM »
Should mostly work.  Things to consider: 4 cyl or 6 cyl models and also Auto/Manual clusters, be sure to pick the correct one.  And don't forget to change the oil pressure light to a sender unit like OOPS said above.
87 Extra Cab 4x4 22RE Automatic turned 3RZ-FE 5 speed
3" IFS suspension lift
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
Re: Guage Clusters
« Reply #4 on: Sep 09, 2010, 08:08:32 PM »
Make sure you get one from a 1992 to 1995 so it matches your wire speedometer.
You can use either a 4cyl or 6cyl model but the tach has to be adjusted accordingly.  There is a little dial adjuster on the tach itself.
Change the oil pressure sender.
Last post Mar 05, 2008, 07:27:46 PM
by dropthattaco
Last post Apr 05, 2009, 09:58:56 PM
by raptome
Last post Aug 05, 2009, 05:27:48 PM
by 4runner17
Last post Aug 26, 2012, 08:30:02 AM
by Red_Runner
Last post Oct 13, 2016, 07:15:58 PM
by daniresch
