1980 1ton Toyota
Started by Crawling82toyota, August 24, 2010, 06:20:02 PM
Crawling82toyota
1980 Toyota short bed 4x4,
Painted Orange and Black
New tail lights and rear wiring harness
Body and frame stripped and cleaned
Trail Gear shock hoops in front, MT Designs rear shock mount
Sky front crossmember, Sky full-width front shackles, Ruff-Stuff Specialties Dana 60 front and rear axle swap kits, Sky GM master cylinder adapter
Toyota Celica seats
Bed Bobbed 13"
Bed Doved 16"
Good, strong running 22R on propane (GotPropane.com kit)
New Toyota V6 aluminum radiator
New GM high-output 1 wite alternator
Orbital battery with new HD cables
Front Chevy dana 60
35 spline
7.17 gears
Lockrite
RPM offroad Drive Flanges
Disc Brakes
Trail Gear front shackles,
RUF springs
HAD Toyota multi-pattern yoke
Ruff Stuff HD Dana 60 Cover with flush mounting bolts
Rear ford Dana 60
30 Spline
Spooled
Disc Brake Conversion
Trail Gear rear shackles
63" Chevy Springs
Blue torch Fab. high steer arms and 1.5x.25 DOM steering with 5/8 heim joints.
Marlin Crawler clutch kit
New clutch master cylinder
HD W-56 5 speed by Marlin Crawler
Marlin Dual Ultimate Crawler (stock gears in first case, 4.70 gears in rear case, twin sticked, muti-flanges)
Bud-Built crossmember with two V-6 tranny mounts
New Long travel rear driveshaft
Square tube front driveshaft
New 1" bore FJ-80 Master Cylinder
Trail Gear stainless steel brake lines
Willwood brake proportioning valve
Brand new Stainless flex lines made by Royal Brass
IFS power steering box with Trail Gear dropped pitman arm
Trail Gear steering stabilizer
custom winch mount
front and rear receivers and d-rings
40"MTR with over 85% tread on all 4 tires
H2 wheels painted black
Rock Sliders
Partial Exo Cage (main hoop runs inside the cab and through the roof)
Tube doors that have stock latches welded on. Takes me about 15 mins to swap the tube doors on to go wheeling.
I had this for sale awhile back because i was moving at the end of summer and i wasnt going to have a place to keep the truck. Well, its the end of summer and i have no place to work on it. I just moved into a 1bd apt.  :thumbdown:
I will also consider selling my barely used pro tools 105hd bender with 1 3/4 die and stand with the truck.
Only issue is the passenger rear axle seal has a leak and i dont currently have time to fix it.
Truck is in San Jose, Ca
Price is $8,000 obo
Here is my build thread and below is a few of the most recent pictures.
Thank you
http://pirate4x4.com/forum/showthread.php?p=10096554#post10096554
Crawling82toyota
Rick Vega
killing it iwith the dana 60's
85 efi 2nd gen. - in progress
Crawling82toyota
studentwheeler
Crawling82toyota
thegoofster21
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
Crawling82toyota
Quote from: thegoofster21 on September 08, 2010, 08:52:02 PM
i'm sure he mean's good deal i think
Thanks i didnt get what he meant...
Throw me an offer i really need this thing gone guys. Worst i can do is say no.
86moneypit
does it go on the street at all or do you have to put it on a trailer if you want to drive to trial i dont have a tow rig. Maybe a built 86 runner to trade i dont know. :biggthumpup:
86 Runner 529s locked duals 37s
96 Runner 5sp. 3.4 32s DD
04.5 Dodge 2500 CTD With Go Fast Stuff On It
Drive it like you stole it
Crawling82toyota
Quote from: 86moneypit on September 11, 2010, 11:39:51 AM
It drives decent on the road. Although its not street legal since the propane. I trailer it where i go.
