Rock Crawling Game
Started by 84krawler, August 22, 2010, 10:02:07 AM
Quick Draw
Quote from: 91 ex-cab on August 31, 2010, 08:14:12 PM
Anyone else think the buggy doesn't have low enough gearing? and i can't wait to download your yota quick draw.
That's easy enough to change.  Open the .truck file for it, and change the values under the "engine" section.  It should be labeled which one is for first gear.  A higher number is a higher ratio.  You could add more gears, or change the final drive ratio too if you wanted.  Again, see "Truck Description File" for more info.
If you want some cool trails, search for "Rock Crawling Heaven" also called "Wild West".
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
91 ex-cab
Quote from: Quick Draw on September 01, 2010, 03:26:30 PM
Ya wild west is the best terrain for crawling i would say, And i might have to try changing the gears.
gnarrkill
#32
That's easy enough to change.  Open the .truck file for it, and change the values under the "engine" section.  It should be labeled which one is for first gear.  A higher number is a higher ratio.  You could add more gears, or change the final drive ratio too if you wanted.  Again, see "Truck Description File" for more info. all i play is wild west
ya thats the only one i wheel
79 toyota duals,caged,40 mtrs
the build thread i dont update
http://board.marlincrawler.com/index.php?topic=65367.0
<MIKE>
how do you wheel the 1980 toyota. i downloaded the file on my mac.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Early
Put the trucks files folder in the Ror/ vehicles folder. I use it on my mac and works like a dream. Haven't been able to get the fj80 in the registery thing to work yet though.
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
minicrawlin
thing is super laggy and it seems like no matter how much i mess with the settings it doesnt change! man i wanted to play this thing looked sweet! Plus the trucks are always white which is weird!
Any ides??
the rocks Rock in South D SON!
Early
#36
I like wild west but kinda wish the lux had a bit bigger tire. Although it would make it easier , maybe too easy. so I'm happy. It's the right amount of truck and skill how it is now.
Curious to hear others preferred views. I've been trying to go between rear, helicopter view and watching the front. What do you guys do?
Also curious if others can see other people while your multiplayer. I looked for info on this but couldn't find any in my lame attempt.
And mini, my iBook (800 MHz processor) didn't like this game at all. My new MacBook (dual fancy prosessor) plays flawless unless I load 7+ rigs
minicrawlin
i dont know man this is all dual core style but maybe it just doesn't quite have the gusto! looks like i'll be buying a new one then ha ha ha
Yotaman139
Where do i got to get the game? and will it work for mac?
Dont be scared.
91 ex-cab
links in the beggining of thread i think, Or search of rigsofrods and its on the website, yes there is a version for mac.
<MIKE>
Quote from: Early on September 01, 2010, 09:46:50 PM
ya i tried that it just says " you can't modify ROR"
1987 4runner
249:1
Quick Draw
I'm not entirely sure, but I think that may be because there are two different "vehicles" folders.  One is for the game as you download it...with the vehicles that are pre-loaded....which I assume you can't modify.  The other should be placed in your documents somewhere that you can modify.
