Author Topic: 22re misfiring  (Read 6719 times)
88yota
  • Turtle Points: -2
  • Male Posts: 83
  • Member since Apr '10
22re misfiring
« on: Jul 16, 2010, 04:19:54 PM »
Hey guys I just replaced my spark plugs in my 22re with Toyota brand ones and they were pre-gapped according to the person at the desk. Now my truck has a pretty bad misfire when its at idle and only at idle. If anyone has any suggestions (replace plug wires?) that would be great. And this wasn't happening before.....
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 22re misfiring
« Reply #1 on: Jul 16, 2010, 09:40:18 PM »
Check the gap.....
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: 22re misfiring
« Reply #2 on: Jul 17, 2010, 12:15:52 AM »
make sure u have firing order right.....
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: 22re misfiring
« Reply #3 on: Jul 17, 2010, 12:35:08 AM »
FTW, you mixed up the wires!
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #4 on: Jul 17, 2010, 09:29:40 AM »
Thanks for the suggestion, I'll check that but I really don't think I did because I took them off one at a time. I'll see! THANKS
  • Male Posts: 9,757
Re: 22re misfiring
« Reply #5 on: Jul 19, 2010, 08:30:47 PM »
And then?
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: 22re misfiring
« Reply #6 on: Jul 20, 2010, 07:05:08 AM »
Trusting the pregapped plugs is a bad idea. always want to check them.  Even tho the fsm says to gap to .031 I always gap to .035 on carbed or efi engines.
  • Male Posts: 9,757
Re: 22re misfiring
« Reply #7 on: Jul 20, 2010, 09:18:29 AM »
Stock ignition doesn't need any bigger than .032, higher output will like them opened up.
crazykooter
  • Male Posts: 1,418
Re: 22re misfiring
« Reply #8 on: Jul 20, 2010, 10:00:28 AM »
Ive been doing it that way for many years now with great results.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
  • Member since Dec '06
Re: 22re misfiring
« Reply #9 on: Jul 20, 2010, 10:25:58 AM »
Are you wires by anychance hitting the exhaust or anything????? I would definately regap the plugs as well.
ascdub
  • Turtle Points: 32
  • Male Posts: 41
  • Member since Nov '08
Re: 22re misfiring
« Reply #10 on: Jul 20, 2010, 10:52:07 AM »
TRY THE EGR MOD MINE WENT BAD AND CAUSED IT TO MISS AND IT FAILED SMOG TOO
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #11 on: Jul 28, 2010, 01:59:21 PM »
Ok guys so I checked the new pre-gapped spark plugs, they seemed to be gapped right. So I went ahead and put the old ones back in, replaced the spark plug wires, made sure the wires are not touching the exhaust, and checked the firing order (matched the numbers on the distributor to the cylinders)....still misfiring. ANY MORE SUGGESTIONS? THANKS
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: 22re misfiring
« Reply #12 on: Jul 28, 2010, 02:03:36 PM »
Check the resistance of the wires.
Check the contacts on the cap and rotor.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
sayanything
  • Member since Jul '10
Re: 22re misfiring
« Reply #13 on: Aug 03, 2010, 10:25:42 PM »
check for spark?
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #14 on: Aug 10, 2010, 03:02:57 PM »
Ok so any more suggestions...or tests. How do I check EGR Mod? Thanks for helping out a noob.
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #15 on: Aug 10, 2010, 03:15:14 PM »
Quick update....it doesn't misfire when I first start it up, but once it gets warm it will start to misfire causing the rpms to go up and down. I have notice it missing a little while driving if I am not giving it gas or right as I shift into a new gear. Thanks guys
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #16 on: Aug 18, 2010, 05:36:00 PM »
I know no one has replied in a while, but it's worth a shot. So, when I changed the spark plugs, I also did an oil change....while I was changing the oil filter I accidentely broke a sensor wire. I'm not sure what sensor it is (it is located by the oil filter a little below and to the left). So, I repaired it (so I think???)..could this be causing the problem (does it not have a good connection??)...I unplugged it and started and it ran like it was before (surging/misfiring). My check engine is not on. THANKS :beerchug:
crazykooter
  • Male Posts: 1,418
Re: 22re misfiring
« Reply #17 on: Aug 18, 2010, 08:41:49 PM »
Below the oil filter is the oil pressure switch and above it to the left is the knock sensor.  If you repaired it then its prob fine and no it wont cause this.   You might want to check the distributor shaft for end play and also the dist. pick up.   Without seeing it in person its hard to say for sure.
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #18 on: Aug 18, 2010, 09:31:33 PM »
Thanks for that info Krazy, I'll check it out! :beer:
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
  • Member since Mar '10
Re: 22re misfiring
« Reply #19 on: Aug 19, 2010, 05:57:56 AM »
You don't have any signs of it having a blown head gasket right?  I'm thinkin not since you said it started happening after you replaced the wires and plugs, but you never know.  No pressurizing of the coolant system, milky oil, did you do a compression test?  Also, really make sure the plug wires are all the way seated on the plugs.
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
88yota [OP]
  • Turtle Points: -2
  • Male Posts: 83
Re: 22re misfiring
« Reply #20 on: Sep 21, 2010, 05:58:12 PM »
Could it be valves? I have VERY bad ticking (speeds up when I rev engine). I will re-adjust them this weekend anyways...but could this be causing the rough idle (misfire,surge)............or am I starting to think it's a blown headgasket. It's not overheating, and it doesn't really look like there is coolant in the oil. Thanks for your help. I've been busy so haven't been working on it.
Last post Mar 03, 2007, 04:06:19 PM
by Tallchevy
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
Last post Feb 13, 2011, 10:22:43 AM
by spuds015
Last post Apr 22, 2010, 02:11:27 PM
by greenseaman
Last post May 12, 2010, 05:25:53 PM
by wakkjobb
